Is there a difference between 2x4 and 4x4 C6 trannys? If so what are the components that are different? Can I turn a 2x4 into a 4x4 if have a broken 4x4 for donor parts??
Yes you can do that. The tailshaft is the main difference. you should be able to swap the parts over just fine as long as you have a complete 4wd C6 to get them from.
