license plate lights not working - Ford Truck Enthusiasts Forums
Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator
Old 10-16-2011, 11:15 PM
hotrod80 hotrod80 is offline
hotrod80 is starting off with a positive reputation.
i have a 2000 expedition and the license plates are not working, i replaced the bulbs but i still have no lights. what could be the problem and or where can i get power from to make the lights work....thanks for the help
Old 10-17-2011, 08:05 AM
I fish's Avatar
I fish I fish is offline
I fish is starting off with a positive reputation.
Without knowing anything else, my bet would be a bad ground. check the wiring coming out of the lamp sockets
Old 10-17-2011, 03:51 PM
Turx Turx is offline
Turx is starting off with a positive reputation.
I agree, probably a bad ground. The lights are single wire, they ground with contact to the bumper. The edges of the holes in the bumper or the contact area of the light fixture, or both could by rusty. Not allowing the ground contact needed. It's not uncommon to need to replace the back-up light fixture itself, as the series of tabs that hold it in deteriorate over time. Regardless it's usually an easy, one wire fix. New ones will either have a male bullet connector that will plug in, or simple splice it in with a weather proof connector.
Red running lights above license plate wiring ssoundwave 2017 Super Duty 41 01-16-2017 07:44 PM
96 F250 License Plate Light Wiring Trouble robfattig88 1987 - 1996 F150 & Larger F-Series Trucks 0 04-13-2016 11:47 AM
License Plate lights not working... Poolshooter2012 1999 to 2016 Super Duty 2 04-08-2012 04:22 PM
license plate lights not working after new bulbs rockos3354 Escape & Escape Hybrid 2 09-23-2010 08:02 PM
bull bar question cdaily91 2004 - 2008 F150 12 12-13-2008 12:24 PM
Tags
06, 2001, 2005, 2006, bulb, classic, expedition, f150, ford, license, lights, plate, plates, ranger, truck, wiring, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
