Bilstein 5100 Shock install with VIDEO!!! - Page 8 - Ford Truck Enthusiasts Forums
Old 11-24-2014, 05:39 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Steering and Suspension Guides
Print Wikipost
  #106
Old 01-28-2012, 03:50 PM
Fontana Fontana is offline
Fontana is gaining momentum as a positive member of FTE.Fontana is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by TexasA&M View Post
Part of the dual set up is definitely bling, but once you go up to a big enough tire, it does make a difference. If you are staying with stock sized tires, there really is no need for it.
The reason to replace the stock stabilizer is the same reason as replacing the stock shocks... the stock stuff sucks.
My $0.02.
I think that with respect to the Fx4 package stock shocks were crap. I switched over to Bilstein months ago and never looked back. In my opinion I believe that the stock stabilizer is good to go. Agree that if you modify with a lift kit and larger tires you may have a need for a Bilstein stabilizer. If you stay stock size tires I would nt spend the money.
  #107
Old 01-28-2012, 03:53 PM
2000silverbullet's Avatar
2000silverbullet 2000silverbullet is offline
2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold
Quote:
I disagree, when you're stock tires are doing what mine are (were) in the video, you may want to upgrade:
  #108
Old 01-28-2012, 03:59 PM
Holy ****! That was scary! Is the the death wobble people have been talking about?
My truck has the snow plow prep package springs and Bilstein 5100 shocks and drives like a dream.
That wheel shake is not acceptable. Do and spend whatever you need to get that crap fixed ASAP.
  #109
Old 01-28-2012, 04:02 PM
EpicCowlick's Avatar
EpicCowlick EpicCowlick is offline
EpicCowlick has a brilliant futureEpicCowlick has a brilliant futureEpicCowlick has a brilliant futureEpicCowlick has a brilliant futureEpicCowlick has a brilliant futureEpicCowlick has a brilliant futureEpicCowlick has a brilliant futureEpicCowlick has a brilliant futureEpicCowlick has a brilliant futureEpicCowlick has a brilliant futureEpicCowlick has a brilliant future
I had the same issue with larger tires. I can't say if it happened with the stock Michellins as I only had them on the truck for about 20 miles. Silverbullet's video is a perfect demonstration as it shows the wobble starting and then quickly coming under control. Almost faster than the naked eye can detect. The slow motion tells all. I figure if you can stop the wobble from happening in the first place with a good shock/stabilizer combo, why not? Even if it happens and is controlled quickly, the suspension will eventually pay a price.
Skip to 6:10 in this video for another view of wobble before and after:
Installing Rancho Steering Stabilizer & RS9000XL Shocks Ford Super Duty - YouTube
  #110
Old 01-28-2012, 05:01 PM
Gunny77's Avatar
Gunny77 Gunny77 is offline
Gunny77 is starting off with a positive reputation.
Quote:
Originally Posted by P.I.T.S. View Post
Stabilizer vs Damper
Not sure what the difference is between that one and this one:
Bilstein Part 24-158848 - Bilstein 5100 Series Steering Damper
Different model year.
Damper and Stabilizer are the same thing.
  #111
Old 01-29-2012, 07:26 AM
dualli f 350 Quebec dualli f 350 Quebec is offline
dualli f 350 Quebec is starting off with a positive reputation.
tank you.
whit this video i realise that my dealers was not right to do tire rotation and looking everywhere els then shock, i do what sarge do and bingo my ford is new....it took me 1hrs. and internet is awesome for information ....
tanks sarge....
  #112
Old 01-29-2012, 10:29 AM
It's not THE death wobble, but it's excessive in my opinion. I told my dealer about it, they took my truck on a 1 mile test drive, then said it's not happening. I told them I had a video of it in my truck on my tablet, they didn't care to see it. Instead of getting into a p***ing match with them, I resolved it myself. I think another OEM stabilizer would've done the same thing over time (truck has 10k miles on it) as the roads out here in PA are terrible.
  #113
Old 01-29-2012, 01:56 PM
Shepardsonp Shepardsonp is offline
Shepardsonp is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by Shepardsonp View Post
I just got my Bilstein 5100's installed with a leveling kit. The ride is definitely better than the stock Rancho's. I have 22,000 miles on my truck and the stock Rancho's all were all functioning - nothing like what Big Sarge experienced at 2,900 miles.
I could have swore that i had some back shocks as my ride was pretty bad.
Definitely a better ride than what i had for sure!!!
CORRECTION!!! I just pulled my Rancho's out of the bed of my truck and was able to completely compress all 4 shocks easily by hand. As I am writing this post, the 2 front shocks have yet to return. Rancho's are a POS Shock!
Shame On FORD
Peace
  #114
Old 01-29-2012, 03:11 PM
lexustbs's Avatar
lexustbs lexustbs is offline
lexustbs is gaining momentum as a positive member of FTE.lexustbs is gaining momentum as a positive member of FTE.
I installed the Carli Bilstein steering stabilizer and my death wobble came back. That was the worst $280 spent ever. I think with the exception of the dual setup, the best stablizer out there is the stock OEM one. Once I installed it back on the truck, no more death wobble. And it was for real death wobble, like wont stop till you stop type.
  #115
Old 01-31-2012, 12:28 PM
Big-Sarge's Avatar
Big-Sarge Big-Sarge is offline
Big-Sarge is gaining momentum as a positive member of FTE.Big-Sarge is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by Gunny77 View Post
Pic of the 5100 Bilstein Stabilizer installed.
Gunny....Can you give me your opinion on how much better the Bilstein stabilizer was over the stock one. If the was the case. Thanks you.
  #116
Old 01-31-2012, 06:41 PM
slowmans's Avatar
slowmans slowmans is offline
slowmans has a good reputation on FTE.slowmans has a good reputation on FTE.
Quote:
Originally Posted by 6.7L View Post
Just wondering if the 6.4L have these suspension problems.
Any one?
it goes all the way back to the upgraded 05' suspension change, its essentially the same thru 12'.........
  #117
Old 02-01-2012, 08:15 AM
TxFordGuy1's Avatar
TxFordGuy1 TxFordGuy1 is offline
TxFordGuy1 is starting off with a positive reputation.
I hope you have better luck with them than I did. They gave me the run around about when it was going to be shipped, ended up cancelling my order.
@ TXFordGuy1, I sprayed the bolt with WD40 and got a BFH (Big friggin hammer) and wacked it a few times, came right out. I am really happy with how it rides now.
Well, finally got my tracking number from Shock Warehouse....so appears to be on the way...but apparently they are just real slow! 3 weeks or so if it get here Monday as scheduled
  #118
Old 02-01-2012, 10:02 PM
biz4two's Avatar
biz4two biz4two is offline
biz4two has a great reputation on FTE.biz4two has a great reputation on FTE.biz4two has a great reputation on FTE.biz4two has a great reputation on FTE.
Arrow
Quote:
Oh my...that is really slow. Maybe they were just out of stock...or something. I ordered my Bilstein shocks from them a few years back...and received them pretty quick.
Good luck with them...
biz
  #119
Old 02-01-2012, 11:54 PM
Gunny77's Avatar
Quote:
The Bilstein makes the steering feel a little more stiff which puts it to where it should have been IMO. I think it was too sloppy.
I also dont have the wobble feeling when hitting pot holes and road imperfections. My front end felt like the video 2000silverbullet posted but not anymore.
The combination of the Bilstein shocks and steering stabilizer have put the suspension where it should be.
Well worth the $ spent.
  #120
Old 02-02-2012, 06:16 PM
I just order a new stabilizateur from summit parts
california.cost $142.00 i just try my new bilstein 5100 and it more stiff,the shaky dashboard have come once after that ,and that s why i order the stabilizateur i hope it will fixe that for reel....
F250 Bilstein 5100 shocks **NEW** 2gumby2 Ford Truck Parts for Sale 0 03-19-2017 09:33 PM
Bilstein 5100s SkipperPete 1987 - 1996 F150 & Larger F-Series Trucks 2 01-03-2017 08:22 AM
bilstein shocks donovan 6.7L Power Stroke Diesel 8 07-26-2016 06:08 PM
Bilstein 5100 part number for F350 - 0-1" or 2-4"? rotaryracer 1999 to 2016 Super Duty 5 08-09-2013 09:16 PM
Bilstein 5100? EMC V10 X Excursion - King of SUVs 4 12-01-2010 09:57 PM
Tags
2001, 2011, 5100, bilstein, duty, exhaust, f150, f250, ford, install, installation, shock, shocks, super, tip
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
