Carb hook up to 351/C-6 - Ford Truck Enthusiasts Forums
Old 10-16-2011, 08:18 PM
kcode kcode is offline
kcode is starting off with a positive reputation.
So I got a new Edelbrock carb 1406 for my 351/C-6 in my 75 truck. I bought an adapter 1483 Ford Throttle Lever Adapter and a 1491 Ford 351W throttle cable plate kit. I put the throttle kit on, but it just does not seem correct.
It does not seem like I have the throttle cable hooked up correctly and I don't see how the kick down CABLE, not rod for the transmission hooks up.
I am guessing from the engine ID number that the 351w is out of an 84 vehicle and I would guess the transmission is also as it has a cable for the kick down.
Does anyone running a similar set up have a picture I could see? Any ideas of what I might do? The spring the kit provided me does not retract the throttle cable and makes me feel like I don't have it connected correctly.
Thanks in advance for your help.
Old 10-16-2011, 10:00 PM
The first few pictures show the old carb and the studs that the cables hooked to. Can I buy those studs and put them on the new carb and take of the adapter I just put on?
HOW TO: Changing Carburetors and Making it Work with an AOD LARIAT 85 '80-'86 HOWTO's 21 11-26-2016 11:09 AM
New Edelbrock avenger, looking for pics of linkage 6ohman2004 1973 - 1979 F-100 & Larger F-Series Trucks 3 11-01-2014 11:23 AM
Carb question? kcode 1973 - 1979 F-100 & Larger F-Series Trucks 6 10-14-2011 01:59 PM
Edelbrock 1406 Install Problems on 351w hozee4 Fuel Injection, Carburetion & Fuel System 4 05-19-2008 04:09 AM
C6 Kickdown/Throttle Cable N7ghtwolf Ford Inline Six, 200, 250, 4.9L / 300 1 09-14-2007 10:21 AM
Tags
1983, 302, 351, 351c, 351w, auto, carb, carborator, carburator, cleveland, f100, ford, forum, hooking, hookup, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
