5th wheel hitch mounting - Ford Truck Enthusiasts Forums
Old 10-16-2011, 07:58 PM
Ford_Six's Avatar
Ford_Six Ford_Six is offline
Ford_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputation
I am preparing to mount a new/used 5th wheel hitch, how far should the pin center be ahead of the axle?
Old 10-17-2011, 03:10 PM
senix's Avatar
senix senix is offline
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
Normally I'd recommend just over center. I would think you could find instructions online for the type of hitch you have.
Old 10-17-2011, 03:12 PM
MisterCMK's Avatar
MisterCMK MisterCMK is offline
Avid Winter Hater
MisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputation
FWIW the center of the B&W hitch in my truck is 46" from the end of the bed. Like Scott said, I would try to find instructions online for your hitch.
Old 10-17-2011, 05:42 PM
BPofMD's Avatar
BPofMD BPofMD is offline
Posting Legend
BPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputation
Go to the web site for your brand/model hitch. Install instructions are there.
Old 10-18-2011, 11:33 AM
r2millers's Avatar
r2millers r2millers is offline
r2millers has much to be proud ofr2millers has much to be proud ofr2millers has much to be proud ofr2millers has much to be proud ofr2millers has much to be proud ofr2millers has much to be proud ofr2millers has much to be proud ofr2millers has much to be proud ofr2millers has much to be proud ofr2millers has much to be proud of
When I put my Reese 16k in, the brackets made for the installation were set up to be directly over the rear wheels.
I think you will find every mfg set's up that way. Only makes sense to balance the load.
Old 10-18-2011, 12:01 PM
BPofMD's Avatar
Posting Legend
Actually I think you will find they sit a few inches IN FRONT of centered over the rear wheels......
Old 10-18-2011, 12:17 PM
r2millers's Avatar
Bud,
You are right. Thanks for correcting me. I just went out and measured and it's pretty close to 3" forward of the rear axle.
My apologizes on this one.
Old 10-18-2011, 12:35 PM
BPofMD's Avatar
Posting Legend
HAHAHA= No problem Bob..... you should see MY collection of corrections!!!! Reps to you!
Old 10-18-2011, 03:49 PM
bpounds's Avatar
bpounds bpounds is online now
2 bit Californian
bpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputation
Judging by Ford_Six's signature and profile, he may be mounting this hitch in a truck old enough that kits and instructions may not be easily available.
If I am right, some on the job training might be required. About 3" forward of the rear axle centerline is a good spot. Anything 2"-4" will work fine. And most importantly, make sure you are mounting this hitch to the frame, NOT to the bed. That may seem too obvious and insulting, but this mistake has been made before.
Old 10-19-2011, 11:12 PM
Ford_Six's Avatar
I have set up quite a few gooseneck hitches, and usually put those about 4" in front of the axle centerline. I wasn't sure if a 5er was the same, but sounds like it's pretty close.
This is the last step in getting my brother in law's truck out of my driveway. It started out as an 88 F350 crewcab longbed 4x4 with a massive lift and twisted frame, now sitting on an 81 E350 1.25 ton RV chassis. It's been a long and interesting project, mostly broken up by his unwillingness to spend money on this truck he asked me to build.
The hitch is an unknown brand, designed to bolt into the bed of a truck so it's a lighter duty hitch, maybe 10-12k. His only trailer is a 28' Alpenlite so I doubt he'll be pushing the limits of the hitch. Besides, his towing experience consists of pulling a 4x8 trailer behind an Astro to the dump maybe once or twice, so I don't expect him to tow this that much anyways.
I mounted a pair of 4x1/2" angles to the frame to mount the hitch on, I'll just bolt the hitch to those. There is about 1" of adjustment in the mounting slots.
Thanks for the input guys.
Old 10-20-2011, 07:58 AM
Gearitis Gearitis is online now
Gearitis is gaining momentum as a positive member of FTE.Gearitis is gaining momentum as a positive member of FTE.
Yep, Yep, Yep, on or slightly forward of the rear axle. A 5er can be as wide as 8.5 ft and 1/2 of of that is 51". Ideally, at least 52" measured from the back window on a long bed, so that measure will keep you out of your rear window. Obviously with a short bed, that is impossible hence the need for a slider hitch and/or extended pin to keep your hitch on top or a hair in front of the rear axle. Mine is right on top of the axle and have not had weight issues as I have weighed on several occassions, fully loaded.
Old 10-20-2011, 10:05 AM
TexasRebel's Avatar
TexasRebel TexasRebel is offline
TexasRebel has a great reputation on FTE.TexasRebel has a great reputation on FTE.TexasRebel has a great reputation on FTE.TexasRebel has a great reputation on FTE.TexasRebel has a great reputation on FTE.
it isn't so much weight issues, but handling issues with heavier trailers.
a 5th wheel/gooseneck is supposed to place weight on both front and rear axle of the tow vehicle, not just the rear. This is because of the dynamic forces. If you are simply looking at the static forces, it seems okay, but when you remember that the weight of the trailer (load) is putting a moment on the rear axle that is only counteracted by the weight of the front of the tow vehicle it makes more sense.
When you go, the trailer tries to lift the front of your pickup off of the ground. If you don't add any of the tongue weight to the front axle, you might as well have just bought a conventional trailer.
That does work both ways, too... too much tongue weight added to the front (hitch point too far forward, and you'll increase wear on your steering system and make it difficult to turn.
Old 10-21-2011, 03:28 AM
BadDogKuzz's Avatar
BadDogKuzz BadDogKuzz is offline
BadDogKuzz has much to be proud ofBadDogKuzz has much to be proud ofBadDogKuzz has much to be proud ofBadDogKuzz has much to be proud ofBadDogKuzz has much to be proud ofBadDogKuzz has much to be proud ofBadDogKuzz has much to be proud ofBadDogKuzz has much to be proud ofBadDogKuzz has much to be proud of
Thanks for explaining the what and why's? I myself am looking to set up my truck for a 5th wheel and I have been following this tread in hopings of understanding more about 5th wheel towing before even buying a 5th wheel hitch or trailer. Thanks reps sent
Old 10-27-2011, 04:46 AM
CougarXR02 CougarXR02 is offline
CougarXR02 is gaining momentum as a positive member of FTE.
I've been looking at instructions on etrailer for universal rails and F-150 specific rails and they are written by the manufacturer at 1 1/2" in front of the axle centerline.
Old 10-28-2011, 12:02 AM
Ford_Six's Avatar
Interesting, I wonder if that has anything to do with the length of the bed? Does it actually say in front of axle centerline, or in front of wheelwell centerline though? Usually the wheelwell bump leads the axle by a couple inches.
2017 and the Fifth Wheel Hitch. School Me. HouseMouse Fifth Wheel & Gooseneck RV Towing 6 12-31-2016 09:59 PM
factory 5th wheel Vinford Fifth Wheel & Gooseneck RV Towing 39 12-15-2016 08:56 AM
Mounting for 5th wheel hitch Jace2016 2017 Super Duty 27 10-28-2016 08:34 AM
WTB - Reese Kwik-Slide 16K 5th wheel hitch BeaverCrap WTB - Parts & other 0 01-16-2016 06:55 PM
Reese Elite 18K 5th Wheel Hitch kdubinwa All Other Items for Sale 3 02-16-2011 07:31 AM
Tags
04, 5th, crew, f250, ford, hitch, hitches, installation, measurements, placement, short, stillwater, trucks, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
