79 F-150 Stepside Restoration - Ford Truck Enthusiasts Forums
Old 10-16-2011, 07:51 PM
ironman540 ironman540 is offline
ironman540 is starting off with a positive reputation.
79 F-150 4x4 in pretty bad shape. These are the only pics of the truck together as we started to dismantle almost immediately. Follow the pics below to see where we are with the build at this time. Anyone with access to a straight front dana 44 and a c6 transmission post back to us, i think the truck was ran pretty hard.
Old 10-16-2011, 08:00 PM
Took the cab and bed off the truck and started to dig into the frame
Old 10-16-2011, 08:25 PM
kevin316's Avatar
kevin316 kevin316 is offline
kevin316 is starting off with a positive reputation.
Looks good. I am in the process of doing a 79 2wd.
You might want to edit your 1st post and put a space between the picture codes. It's tough to read the way it is.
Old 10-16-2011, 09:15 PM
Hope I fixed it still a little new to this
Old 10-16-2011, 09:20 PM
Finished taking most things off the frame
Old 10-16-2011, 09:29 PM
mightymoose95's Avatar
mightymoose95 mightymoose95 is offline
mightymoose95 is starting off with a positive reputation.
haha my daily driver is a 79 f-150 FLARESIDE =p, we've redone the wood in the bed and some other small things,next thing is rebuilding the 351m though its got 193.xxx miles and still runs stong, cant wait to put a 4bbr on her and bore her out!
Old 10-16-2011, 09:38 PM
Quote:
Cool, I hope one day this becomes my daily driver
Old 10-17-2011, 01:13 AM
79 shortbed lover's Avatar
79 shortbed lover 79 shortbed lover is offline
79 shortbed lover is starting off with a positive reputation.
I have a front hp44 front housing but I may be a ways away from you. I live in Hurricane Ut.
Old 10-17-2011, 08:07 PM
Quote:
Im located in Va so thats a little to far but thanks anyway
Old 10-17-2011, 08:55 PM
Fully stripped the frame and got ready for painting.Used KBS brand paint system with a rust remover and rust sealer on parts and on the frame.The process was smooth and I was pleased with the product.
Before:
After:
Old 10-22-2011, 12:57 PM
txlightning txlightning is offline
txlightning is starting off with a positive reputation.
nice project,,
fyi if the data is true that i have been told,, they only made 718.. 4x4 stepsides in 79,,
keep that in mind when you start re-assembly,,
i have both a 78 4x4 stepside--mountain/trail rig,,
and a cleaner 79 4x4 stepside--it has the original block and trans etc.. going thru the engine currently,,
good luck and keep the post and pictures going
Old 10-23-2011, 01:10 AM
blkmesamtman blkmesamtman is offline
blkmesamtman is starting off with a positive reputation.
I also have a '70 F-150 step side 4x4. I've just about finished up the mechanical repaires and have gutted the interior which was trashed!! I have also been working on repairing the electrcal wiring that the PO had jury ridded big time. I hope to have it up and running and drivable soon.
Ironman, there is a place up near Akron OH that the owner has a "gold mine" of old Fords and parts. It's called Todd's Garage in Norton OH. He may be able to help with parts, if it's not too far for you.
Old 10-23-2011, 03:29 PM
have to make a call tomorrow to BDS suspension. no instructions for rear lift and not sure whether to reuse the factory blocks, if so the ubolts supplied aren't long enough. everything that was loose is now bolted on, will be idle for a little while on the frame until front axle and engine and repaired. gotta say really happy with it so far.
Old 10-24-2011, 07:45 AM
teds74ford's Avatar
teds74ford teds74ford is offline
teds74ford has a good reputation on FTE.teds74ford has a good reputation on FTE.teds74ford has a good reputation on FTE.
Looking good!
Old 01-01-2012, 09:26 PM
Grandpa has been hard at work on the body, some pics of his progress
Finally found another front axle housing although the carrier gears were missing all the teeth. Charlie at 4WD Specialty in Richmond, VA put everything together, new bearings, new universals, new seals, practically brand new. Wish I new how to set it up, dont' have that experience. Anyway, epoxy painted the front axle and all the other parts to get ready to put under the frame, hopefully have a rolling chassis in the next couple of days. Found a shop to repair the front cab mount, next thing to do is learn to weld.
Will post some pics when we have it rolling.
New cb & antenna install Davgt500 6.7L Power Stroke Diesel 31 11-18-2016 10:00 AM
Eddy Myrtle Sac79 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 94 02-13-2016 12:32 PM
48' F1 PROGRESS BUILD !! cashy52 1948 - 1956 F1, F100 & Larger F-Series Trucks 45 09-07-2015 10:35 AM
A little OT, just some recent pics of the trucks plgebbia 1994.5 - 1997 7.3L Power Stroke Diesel 38 05-02-2011 08:39 PM
2010 FTE '57-'96 General Championships-Round-7 76f350spercamprspeal Picture competitions 19 09-12-2010 09:19 AM
Tags
150, 1967, 1979, 4x4, 79, 79 ford, f150, ford, ford f-150, frame, project, restoration, stepside, truck, tx
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
