79 F-150 Stepside Restoration - Page 8 - Ford Truck Enthusiasts Forums
  #106
Old 10-01-2013, 03:44 PM
ironman540 ironman540 is offline
ironman540 is starting off with a positive reputation.
There were times that I thought this day would never come. It is legal, plates, inspection, insurance, legal.
You can catch a glimpse of the Ford emblem on the seat through the windshield.
Rode pretty well, tracked straight and true, makes you feel 20 years younger. Got it up to about 70 and developed a noticeable vibration that we will need to investigate. Carpet and some work on the steering column are left but nothing that would keep you from driving it around town. Need to get some miles on it right now so keep a look out this baby is on the road.
  #107
Old 07-08-2014, 12:17 PM
finally installed the carpet
carpet in
  #108
Old 07-09-2014, 09:31 AM
and since the dome light doesn't do that well for finding items behind the seat at night we installed a set of LED's on either side of the speaker box
during the day
and at night
  #109
Old 07-15-2014, 09:04 AM
a new project for the old truck, the turn signal does not turn off when the wheels are straightened and there is so much slop in the gear shift lever (due to pin wear) that is knocks the cover off of the transmission indicator everytime you put into park, so pulled the steering wheel and associated pieces.
when I pulled the steering wheel there was a small white cover over the upper bearing, pic below. Appears there should be 2 studs (spring loaded) in this but you can see from the wear that one is missing and all the metal was behind the steering wheel. What is this piece and what does it do, is it required prior to reinstalling the steering wheel or was it something for cruise control, or is this what actually turned the blinkers off when back to center. (I do not have cruise)
  #110
Old 07-15-2014, 05:11 PM
oddfordjunkie oddfordjunkie is offline
oddfordjunkie is gaining momentum as a positive member of FTE.
Those pins are the contact points for your horn (and CC if you had it).
  #111
Old 08-06-2014, 06:58 PM
Actually as it turns out this little piece is what shuts off the turn signal when you straighten the truck up. Replaced and works fine. Was able to find a OEM steering wheel on EBAY for a decent price and replaced it along with a new collar for the shifter since the pin was wollared out. Will post pics of the completed steering column in the next few days. Had to watch a 74 bronco II get put back together to understand what the T-bolts were for which held things up a couple of days. Thanks for the suggestion.
  #112
Old 08-06-2014, 07:00 PM
the contact pins for the horn are fairly obvious when you disassemble as they are fairly large brass (copper?) pins that meet the underside of the steering wheel and ride in 2 separate groves as the wheel turns. DO not have pics but have seen in other posts.
  #113
Old 09-07-2014, 12:07 PM
While replacing the turn signal switch also replaced the steering wheel with used OEM and replaced the pin in the transmission shift lever. Straightened the wheel while it was off, although it does not appear that way in the pic.
Old steering wheel, note number of cracks
  #114
Old 01-06-2015, 07:01 AM
monkey-1 monkey-1 is offline
monkey-1 has a good reputation on FTE.monkey-1 has a good reputation on FTE.
Great looking truck! Any more updates?
  #115
Old 01-23-2015, 12:27 PM
Not up for the winter but was surprised at how quickly the wood in the bed was deteriorating/discoloring even with 3 coats of marine grade poly.
Still have to get the gas gauge working and although it may sit for a couple weeks at a time still starts right up.
<br/>
  #116
Old 02-07-2017, 10:43 PM
Santiago Williams Santiago Williams is offline
Santiago Williams is starting off with a positive reputation.
AWESOME THREAD
<br/>
Hello, very great thread and even better truck sir. I Hope You get this notification, I am actually starting to restore the exact same truck. It was supposed to be a Father/son build (truck has been in the family my whole life and used to be amazing then I'm not sure what exactly happened but it needs to be restored.)and we did work on it for awhile after we moved to Texas but so much happened and didn't have the time or money to work on it. My dad is now in jail, and he may be there for a few years so I am planning on restoring the truck as a surprise for him and pick him up when he gets out. I would love to give you details on what I want to do with the truck/ and what I've done with it I'll also send pictures. I would appreciate it if you would be able to guide me in the right direction and help me out with questions that I have. You can email me at santiwilliams1@gmail..com
  #117
Old 02-08-2017, 01:09 PM
CelticOne's Avatar
CelticOne CelticOne is offline
CelticOne is a splendid one to beholdCelticOne is a splendid one to beholdCelticOne is a splendid one to beholdCelticOne is a splendid one to beholdCelticOne is a splendid one to beholdCelticOne is a splendid one to behold
Quote:
You came to the right place to get help in restoring your truck. Not just from the author of this thread, but many others as well. Welcome to FTE!
The best way to get help/advice is to start your own thread. Let us know your plans for the truck and it's current condition. And post lots of pictures. We like pictures.
I appreciate the love and loyalty you show towards your dad. We all make mistakes - I've sure made my share - and we all have the chance for redemption.
  #118
Old 02-08-2017, 01:15 PM
Y
Yea I meant to put "anyone else can message me for help as well" but I accidentally clicked send. Anywyas thank you. I'll go ahead and make a thread now because I am having some major trouble trying to get the Windows put the door.
  #119
Old 02-10-2017, 01:17 PM
Jonnyuma's Avatar
Jonnyuma Jonnyuma is offline
Jonnyuma is starting off with a positive reputation.
I wish my boys had restored my truck while I was in jail...it was only for a few hours and they were 6 and 9, but still...
  #120
Old 02-10-2017, 02:30 PM
CelticOne's Avatar
Quote:
Bad Habit all dressed up for a night on the town bad_habit_F350 1973 - 1979 F-100 & Larger F-Series Trucks 16 05-09-2014 04:20 AM
89' f150 pics. proof that bricknoses can look good Nally427 1987 - 1996 F150 & Larger F-Series Trucks 20 09-08-2012 10:04 AM
Will these fit on a slick? 429unibody 1961 - 1966 F-100 & Larger F-Series Trucks 4 10-07-2011 03:03 AM
Pics of my 1977 SuperCab 77 Supercab 1973 - 1979 F-100 & Larger F-Series Trucks 12 08-10-2011 08:46 PM
D60 RSK Swap with Pics jchosler 1994.5 - 1997 7.3L Power Stroke Diesel 26 01-24-2011 06:42 PM
Tags
150, 1967, 1979, 4x4, 79, 79 ford, f150, ford, ford f-150, frame, project, restoration, stepside, truck, tx
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
