79 F-150 Stepside Restoration - Page 3 - Ford Truck Enthusiasts Forums
  #31
Old 01-21-2012, 08:00 AM
White76 White76 is offline
White76 is starting off with a positive reputation.
I ended up using my factory blocks and it sits a touch lower in the front...I will try to get pictures today when I get the rear shocks on.Are you planning on extending your drive shafts
  #32
Old 01-21-2012, 09:32 AM
ironman540 ironman540 is offline
ironman540 is starting off with a positive reputation.
Quote:
Not at this point. When I lifted one 20 years ago it was 6" worth of lift and didn't have any trouble and ran it fairly hard. This lift is only 4" so I think we will be fine.
  #33
Old 01-21-2012, 01:35 PM
bucks77ford's Avatar
bucks77ford bucks77ford is offline
bucks77ford has a very good reputation on FTE.bucks77ford has a very good reputation on FTE.bucks77ford has a very good reputation on FTE.bucks77ford has a very good reputation on FTE.
Nice progress so far. Lookin good.
  #34
Old 01-28-2012, 06:41 PM
Not a lot to post, pulled muscle in back slowed things down over the last couple of weeks. Fortunately teenager can do most things by himself.
Did get the transmission back, if had not posted the case was broken completely out in several pieces where the starter bolted to. It was held together with some bailing wire and large washers. As soon as we loosened it from the engine it all fell out on the ground. Mountain Rd Transmission in Montpelier found a used casing and rebuilt when transferring. Not sure if the lugs on each side will interfere when putting back in the truck but time will tell. Wasn't expecting it to be painted. Those guys were great to deal with and they rebuilt it to drag race while pulling a camper.
Was able to get an "original" push bar from Martins2141 here on FTE. Was a little beat up and appears to have been painted white, then red and finished in light blue as arrived. It is about 1.5" wider than the frame so not sure how it was bolted (spacers?) on originally. Will have to bring the bumper back here and fit it all together to see what will need to be modified. Son spent the day cleaning it all up with the grinder and hitting it with some etching primer. It is pitted in several places so a little work left to do. Attached some pics of it as he worked. Oh yeah you will notice the trash bag and WV door mat over the front axle. Haven't installed the breather hose yet and got some rain over the last few weeks.
And he did a little work on the front hub. Kind of got ahead of ourselves when we put the front end back together. Cleaning up some of the details while we have nice weather and it gave me an excuse to order a pizza. Still some paint needed to make it "shiney".
  #35
Old 01-28-2012, 07:39 PM
justforkicks's Avatar
justforkicks justforkicks is offline
justforkicks is gaining momentum as a positive member of FTE.
That brush guard looks like it may have been off of a 80-96 era ford. They had wider frames. Nice build so far! Subscribed!
  #36
Old 01-29-2012, 08:24 PM
nutinbutford nutinbutford is offline
nutinbutford is starting off with a positive reputation.
nice work ironman540! you'll have an awesome truck when you're done. Keep the pictures coming.
  #37
Old 04-11-2012, 01:12 PM
Been awile since the last post. Worked this past weekend to replace cab post and bottom panels on bedside. Turned out pretty nice.
Brought the front clip back and worked to get it cleaned up. Few cans of spray paint and some elbow grease and it turned out pretty nice.
  #38
Old 04-21-2012, 12:42 AM
Howell05 Howell05 is offline
Howell05 is starting off with a positive reputation.
nice re-build. when your done with that one you can come work on mine. lol
  #39
Old 04-21-2012, 10:50 AM
earthquake68's Avatar
earthquake68 earthquake68 is online now
earthquake68 has a very good reputation on FTE.earthquake68 has a very good reputation on FTE.earthquake68 has a very good reputation on FTE.
Lookin' good so far.
  #40
Old 04-22-2012, 05:53 PM
belk42 belk42 is offline
belk42 is starting off with a positive reputation.
looks good!
  #41
Old 10-28-2012, 06:41 PM
Have not posted since before summer, busy, heat, etc but work has continued. Grandson and Grandpa spent some quality time this summer working the body straight and have gotten several pieces painted. Original truck was midnight blue, but between the two of them, they went in a different direction. Do not believe I have seen one painted this way.
[/IMG]
[/IMG]
Hood scoops also!!
[/IMG]
Got the engine block back from Beaverdam Auto. Franky was a great guy to talk to, get ideas from, excellent work. Had to wait a bit as he must have had 30 engines in the shop, short track and drag track seasons were getting ready to start. Certainly not building a race engine, but some aftermarket pieces dressed it up pretty well.
[/IMG]
Dropped the engine, transmission, transfer case in the frame, starting to look like something now.
[/IMG]
  #42
will post more pics as we get some more done. batton down for Sandy.
  #43
Old 10-28-2012, 06:56 PM
JunkyardFord JunkyardFord is offline
JunkyardFord is starting off with a positive reputation.
Your progress is looking really good.. Hope Sandy does not affect you all too much!
  #44
Old 10-28-2012, 07:56 PM
uploaded most recent pics of the work we have done. didn't realize when we bought the spark plug wires that it did not come with coil wire, what is up with that??? looking really good from my perspective. can't wait to see it all come together.
[/IMG]
[/IMG]
[/IMG]
Still lots to do, but moving in the right direction
  #45
Old 10-28-2012, 11:38 PM
BiGGreen350's Avatar
BiGGreen350 BiGGreen350 is offline
BiGGreen350 has a brilliant futureBiGGreen350 has a brilliant futureBiGGreen350 has a brilliant futureBiGGreen350 has a brilliant futureBiGGreen350 has a brilliant futureBiGGreen350 has a brilliant futureBiGGreen350 has a brilliant futureBiGGreen350 has a brilliant futureBiGGreen350 has a brilliant futureBiGGreen350 has a brilliant futureBiGGreen350 has a brilliant future
very cool build i like the look
48' F1 PROGRESS BUILD !! cashy52 1948 - 1956 F1, F100 & Larger F-Series Trucks 45 09-07-2015 10:35 AM
89' f150 pics. proof that bricknoses can look good Nally427 1987 - 1996 F150 & Larger F-Series Trucks 20 09-08-2012 11:04 AM
1979 400 engine build w/pics 79Montanalariat 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 15 09-07-2012 02:44 AM
Pics of my 1977 SuperCab 77 Supercab 1973 - 1979 F-100 & Larger F-Series Trucks 12 08-10-2011 09:46 PM
D60 RSK Swap with Pics jchosler 1994.5 - 1997 7.3L Power Stroke Diesel 26 01-24-2011 07:42 PM
Tags
150, 1967, 1979, 4x4, 79, 79 ford, f150, ford, ford f-150, frame, project, restoration, stepside, truck, tx
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
