79 F-150 Stepside Restoration - Page 2 - Ford Truck Enthusiasts Forums
Old 01-01-2012, 11:10 PM
Tsoptich's Avatar
Tsoptich Tsoptich is offline
Tsoptich is starting off with a positive reputation.
Sucribed. I like the tri-pods that you made to hold everything off the ground to hit it with a good coat of paint.
Old 01-02-2012, 12:10 AM
artichack's Avatar
artichack artichack is offline
artichack is starting off with a positive reputation.
Awsome....wish I had your shop.....and nice temperatures.....exaclty what I want to do with my 79 2wld short bed....how hard was taking the cab off..and how did you do it....goodluck...will keep up on your progress....
Old 01-02-2012, 02:41 PM
ironman540 ironman540 is offline
ironman540 is starting off with a positive reputation.
Quote:
Grandpa(my father in law) in WV has the bigger of the two garages and is the retired body mechanic - that is where all the body parts are located.
My wife wishes I had a shop that wasn't called the garage. This is where all the mechanical pieces are located, engine, transmission, frame, etc. Me and my son are the mechanical nerds.
Eastern VA saturday and sunday was in the mid-60's, epoxy paint lower temp was 55, jumped at the chance.
There were five of us that lifted the cab off the frame and walked it to the rear of the truck once we had the bed removed. Gutted the interior and took the doors off to lighten it up. I read somewhere that lifting it with a board through the windows can buckle the cab.
Old 01-02-2012, 05:50 PM
AntiHero55's Avatar
AntiHero55 AntiHero55 is offline
AntiHero55 is starting off with a positive reputation.
where at in VA are you? im just south of Richmond in Chester. and it looks like a nice truck and some good progress!
Old 01-02-2012, 07:40 PM
77393's Avatar
77393 77393 is offline
77393 is starting off with a positive reputation.
Nice job guys. Looks like you off to a good start.
Old 01-03-2012, 03:31 PM
MyName1sMud's Avatar
MyName1sMud MyName1sMud is offline
MyName1sMud is gaining momentum as a positive member of FTE.
Looking Good!
Old 01-03-2012, 09:13 PM
Rolling Chassis
Said I would post an update when the chassis was rolling. Took advantage of the nice weather in Richmond this past weekend. Note the front differential cover that was a Christmas present. Hope to have the shocks and front end finished by the end of February.
Old 01-03-2012, 09:15 PM
mightymoose95's Avatar
mightymoose95 mightymoose95 is offline
mightymoose95 is starting off with a positive reputation.
lookin great- the skulls a nice touch!
Old 01-03-2012, 09:17 PM
anyone having a set of the steering stabilizer brackets would be helpful, this truck supposedly was wrecked (ran over dad after 2 year old pulled it into neutral) and these brackets are missing. I am talking about the piece that bolts to the drag link and under the first piece of cross frame on the truck.
Old 01-03-2012, 10:04 PM
grinnergetter's Avatar
grinnergetter grinnergetter is offline
grinnergetter has a good reputation on FTE.grinnergetter has a good reputation on FTE.
Black frames and cad plated bolts are cool. Looks awesome.
Old 01-04-2012, 09:41 AM
teds74ford's Avatar
teds74ford teds74ford is offline
teds74ford has a good reputation on FTE.teds74ford has a good reputation on FTE.teds74ford has a good reputation on FTE.
Quote:
I have it. Unfortunately, I am nowhere near my truck for a while. For what it's worth, I took the stabilizer off my other truck and had no problems. I didn't really like it on there. Anyway, if you can wait a while (months) I could get you mine.
Old 01-15-2012, 01:27 PM
Not a lot to update but thought would add a couple of pictures that have a little but of color. Not that the shocks need put on at this time but trying to get some space cleared out in the garage. You can see where the front cab mount has been repaired, completely ate out with rust right at the hole prior.
Tried to save the old tank but quite literally full of holes once we started the cleaning process. Old straps and linings top and bottom cleaned up real well. Planning on NOT replacing the tank vent line to the front of the truck.
  #28
Old 01-20-2012, 06:24 PM
ReedRepower ReedRepower is offline
ReedRepower has a brilliant futureReedRepower has a brilliant futureReedRepower has a brilliant futureReedRepower has a brilliant futureReedRepower has a brilliant futureReedRepower has a brilliant futureReedRepower has a brilliant futureReedRepower has a brilliant futureReedRepower has a brilliant futureReedRepower has a brilliant futureReedRepower has a brilliant future
lookin great!
  #29
Old 01-20-2012, 06:52 PM
White76 White76 is offline
White76 is starting off with a positive reputation.
I had the same problems with my BDS lift so I just went to my local suspention place and they made the u bolts for me.
  #30
Old 01-20-2012, 07:31 PM
White76,
did you end up keeping the factory blocks? I did buy the replacement spring set since the ones I had, had leaf(s) broke in both sides. It looks pretty good sitting without any weight on it and once the motor and coil have settled I am actually afraid it will not be level, with the front lower than the back. Thought I was buying quality, not so sure of that now. 20 years ago when I put the first 79 flare side together the kits have become much more complicated and much more expensive for the basic parts. Can you post pics of what your ride turned out like? Thanks for the post.
48' F1 PROGRESS BUILD !! cashy52 1948 - 1956 F1, F100 & Larger F-Series Trucks 45 09-07-2015 10:35 AM
89' f150 pics. proof that bricknoses can look good Nally427 1987 - 1996 F150 & Larger F-Series Trucks 20 09-08-2012 11:04 AM
1979 400 engine build w/pics 79Montanalariat 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 15 09-07-2012 02:44 AM
Pics of my 1977 SuperCab 77 Supercab 1973 - 1979 F-100 & Larger F-Series Trucks 12 08-10-2011 09:46 PM
D60 RSK Swap with Pics jchosler 1994.5 - 1997 7.3L Power Stroke Diesel 26 01-24-2011 07:42 PM
Tags
150, 1967, 1979, 4x4, 79, 79 ford, f150, ford, ford f-150, frame, project, restoration, stepside, truck, tx
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
