78 F-250 Ignition Switch & Pigtail - Ford Truck Enthusiasts Forums
Old 10-16-2011, 04:11 PM
jschluter jschluter is offline
jschluter is starting off with a positive reputation.
I need to remove the ignition switch from my '78 F-250 P/U and need help with the secret to releasing the individual spade connectors on the wiring. I've poked and pulled with zero luck. And in case things go badly, does anyone have a source of a pigtail for the '78 model switch? NPD & LMC have 73-76 pigtails as does RockAuto, but I can't find one for the '78.
Old 11-27-2011, 12:51 AM
AK FORD GUY's Avatar
AK FORD GUY AK FORD GUY is offline
AK FORD GUY is gaining momentum as a positive member of FTE.AK FORD GUY is gaining momentum as a positive member of FTE.
I know this is an old thread, but did you ever figure out how to get the female spade connectors out of the ignition switch plug?
Old 11-27-2011, 09:34 AM
fmc400's Avatar
fmc400 fmc400 is offline
MSEE
fmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud of
There are generally two types of removable crimp terminals used in Ford wiring harnesses:
(1) Spade terminals with clips; the access is on the front. You must hold the crimp terminal in place in the housing from the back, while pushing the clip down from the front. The wire then slides out. You'll have to bend it back in place before reinstalling.
(2) Block spade terminals, which are larger. They are held in place by a tab in the pigtail itself. These are removed by bending the plastic tab from the back, and sliding the wire out. These are much easier to deal with.
It has been a while, so I can't remember which. If each connector has a small keyway on the front of the pigtail above the center of where the spade terminal from the switch would insert, it's the first type. If not, it's the second type.
In either case, you have to disconnect the switch first; you cannot remove the individual wires with the switch connected. You do not have to remove the individual connectors first to remove the switch, otherwise it would be a chicken and egg problem. If all you need to do is replace the ignition switch, you don't need to worry about the pigtail itself unless it's burnt or damaged in some way. Access is tight, but the pigtail does not need to be disassembled. I have not seen the pigtail sold for 78 models.
Old 11-27-2011, 09:45 AM
The problem was in my switch so when I finally got the connector off, I did not have to replace individual wires in the connector. One was loose and did come out. They seem to be anchored by a protrusion inside of the socket in the connector that mates up with a hole in the side of the female spade connector inserted in that socket. I have photos so if you want to e-mail me at jschluter@ctesc.net, I can give you an idea of what the parts look like.
Old 11-27-2011, 10:17 AM
fmc400's Avatar
MSEE
Quote:
Sounds like number 2 then. Thanks for the follow-up.
Old 11-27-2011, 10:30 AM
There is a keyway on the front of the black plastic connector that runs along one side of the inserted female spade connector. One long side of the rectangular cross section of the female spade connector has a square hole and this appears to be the "lock" with the molded protrusion inside of the hole in the black plastic connector. Again, a photo may be worth a thousand words.
Sensor Pigtail replacements viper29 6.0L Power Stroke Diesel 5 09-17-2015 07:14 AM
Pigtail number for upfitter "button" switch? taxgod4u 2009 - 2014 F150 2 03-03-2015 04:13 PM
Valve cover pigtails Diesel_Brad 1994.5 - 1997 7.3L Power Stroke Diesel 13 11-26-2014 09:54 PM
Stop lamp switch pigtail! Mercurypsycho 1973 - 1979 F-100 & Larger F-Series Trucks 4 08-03-2013 08:56 AM
Help! Ignition switch pigtail 73 ford guy 1973 - 1979 F-100 & Larger F-Series Trucks 7 10-15-2011 04:13 PM
Tags
1977, 1979, 78, bronco, f150, f250, ford, ignition, igtion, ingnition, pig, pigtail, power, switch, tail, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
