No Start after Head Gasket Replacement
As usual, I probably did something wrong. I've finally managed to get my 2005 F350 back together after several weeks of tinkering with it and waiting for parts and tools.
I've drained the batteries now trying to get it to start. I've tried for a few minutes, and it doesn't seem to want to fire at all. I'm guessing the problem may be with the injector harness plug under the injector controller. I though I got them all to click in....
Fuel is definitely getting to the filter. Is there anything else I should check or do? It's full of oil and coolant, and completely back together. I don't see anything obviously wrong. Would a no-start condition come about due to vacuum lines being connected incorrectly? I'm fairly certain I've got them connected correctly, but not 100% certain.
the next thing I would be checking is the HPO
did you replace the stand pipes and dummey plugs and STC fitting
do you have a way to monitor ICP and IPR%
It does usually take a few to get the air out the HPO but if you have had it turning over for around 2 minutes or so inbetween resting that should be enough
Dont worrey about the vaccum lines they dont have anytrhing to do with it
Forgive my ignorance.
HPO? High-Pressure Oil?
ICP?
IPR%?
Stand pipes?
Dummy plugs?
STC Fitting?
Wow. I couldn't be more clueless.
I'm guessing that the "stand pipes" are the oil rail lines that go down into the block. No. They were not replaced. They were reused. The ones that came with my head gasket kit were not the correct type for my oil rail. I removed no plugs from the oil rail, so I didn't have to replace any plugs. If the STC fitting is the fitting on the passenger side valve cover, then no, it was reused.
ICP?
IPR%?
Stand pipes?
Dummy plugs?
STC Fitting?
ICP?
IPR%?
Stand pipes?
Dummy plugs?
STC Fitting?
ICP?
IPR%?
Stand pipes?
Dummy plugs?
STC Fitting?
The Standpipes and dummy plugs should of been updated since you were in there at the time, Not something that has to be done, just would have been a good thing to do.
I reused my Standpipes and dummy plugs when I did the HG's on mine
Heres a good link for all the accronyms
https://www.ford-trucks.com/forums/821641-acronyms.html
You can use a DVM at the ICP sensor to see if your making High Press Oil
IIRC you need .8volt to start
and maybe I just have good batterys cuz Iv never had them go dead trying to restart it after the work and I forgot to fill the HPO reservoir last time I did the oil cooler
I'm getting fuel pump buzz. I'm not sure what injector buzz sounds like, but there's a period of buzzing after the glow plug light goes out and before the fuel pump buzz stops.
Check your IPC sensor voltage while cranking. Make sure you're getting at least 500 PSI in the high pressure oil system to start. Need .8 volt as a minimum.
http://napaautotech-classsupport.com...ASTEST1WEB.pdf
In this PDF, your ICP is the right-side picture (on front of the passenger valve cover).
If you have good HPO pressure (or not), this is where you need to go
https://www.ford-trucks.com/forums/8...condition.html
I'm only getting about 0.019 volts. Does this imply a bad sensor, since it's way out of range. This wouldn't surprise me. The little white cage inside the sensor connector came out with the plug connector.
I'm not throwing any codes. The MIL is not on.
The IPR connector is connected to the IPR (I believe it's connected correctly, with the snap wire to the driver side). I can just touch it with my hand, but if I remove the injector control module, I might be able to manipulate it a little better. Is there a better access to this connector?
The instructions say to contact Ford for an IPR connector. Is there a part number for this? My Ford dealer is pretty useless without one. Anything else I should pick up while I'm there? It also says to connect a air pressure connector to the HPOR. Is that available from Ford?
That KOEO is too low.
If I understand, you're getting .019 while cranking? You should see .8 minimum for 500 PSI.
Try unplugging the ICP sensor and see if it will crank. If not, it sounds to me like you need to find an HPO system leak.
Are you getting any codes? Do you have a way to scan?
I disconnected the ICP. It did not start. It produced code P2285.
Where are the most common places for the HPO to leak? I'm guessing that the very low reading on the passenger side pressure rail suggests that my leak is probably near there.
Also, while cranking it almost sounds like it accelerates and slows down. Is that expected? Like don-don-dondon-don-don-dondon.
Honestly, I would go back through the No Start checklist in the Tech Folder. Yes, your ICP voltage is way too low to start the motor, but double check your connectors, fuses, harness, etc. I'm sure by now you've looked at every connection 4 times, but use that checklist as a resource. You may get lucky and find something easy.
