will 07 rims fit an 09? - Ford Truck Enthusiasts Forums
Old 10-16-2011, 12:22 PM
wildstang's Avatar
wildstang wildstang is online now
VT Chapter Ldr
wildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputation
My friend has an 09 and found some 07 rims to possibly buy as winter rims. Same diameter but will the bolt pattern and offset be the same or close enough? Thank you.
Old 10-16-2011, 02:37 PM
shortride's Avatar
shortride shortride is offline
shortride is gaining momentum as a positive member of FTE.shortride is gaining momentum as a positive member of FTE.
The bolt pattern is the same on '04 F150 to 2011.
Old 10-16-2011, 02:54 PM
wildstang's Avatar
VT Chapter Ldr
Thanks shortride. Any idea about offset difference if There is one?
Old 10-16-2011, 05:44 PM
shortride's Avatar
Sorry but I know nothing about what the off-set may be on wheels I know nothing about. All I could tell you is if the wheels are OEM Ford wheels they are interchangeable. I've seen '07/'08 wheels mounted on 2009/2010 F150. The 2010 FX4 20 wheels I put on my 2010 XLT Screw seem to have a little more off-set than the stock 18 wheels I took off.
Old 10-16-2011, 06:51 PM
wildstang's Avatar
VT Chapter Ldr
Thanks shortride, if you have seen 07 rims mounted on a 10 then they should work.
Old 10-16-2011, 08:48 PM
tseekins's Avatar
tseekins tseekins is offline
tseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputation
Quote:
'03 and newer Expedition rims would work also.
Looking at the wheels on my '04 expy and my '11 truck, they seem to be identical in offset and all other attributes.
Old 10-16-2011, 11:28 PM
wildstang's Avatar
VT Chapter Ldr
Thanks Tim. It would would be good for Ford to use the same wheels
Old 10-17-2011, 05:37 AM
Tylus's Avatar
Tylus Tylus is offline
Nuclear Machinist Mate
Tylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputation
all 17/18" rims from 2004-current F-150 have the exact same width and offset. all are same bolt pattern...7.5" wide btw
all 20" rims are 8.5" wide and the offset is slightly different from the 17/18" rims. They are wider than the smaller rims due to smaller sidewall. has exact same bolt pattern though.
other options for rims that will fit your truck
2003-current Expedition
2003-current Navigator (be careful as some had a 1/16" smaller hub and they get stuck on axle)
2004-2008 Mark LT
Saleen F-150 has 23" rims...they fit. are staggered though, 9" wide front, 10" wide rear
Roush F-150 has 20" rims...they fit. believe they are 9" wide
Harley F-150 has 22" rims...they are darn pretty IMO...and they fit
Old 10-17-2011, 06:16 AM
wildstang's Avatar
VT Chapter Ldr
Thank you Tylus. That opens up even more options.
By the way, your truck looks sweet.
09 F350 Harley Davidson 20" Factory Superduty Rims croozer Excursion - King of SUVs 118 12-31-2015 02:24 PM
07 22" harley rims on a 03 expy ZEPHYRMIKE Expedition & Navigator 0 04-24-2014 08:41 PM
what rims do I get so that the rims dont stick out too much ? Htarpley80 2004 - 2008 F150 0 03-13-2014 10:22 AM
09 f350 rims dramirez163 1999 to 2016 Super Duty 2 12-30-2013 07:54 PM
Rim Question bchez 2004 - 2008 F150 12 03-23-2011 07:00 PM
Tags
07, 08, 09, 2008, 2010, 22, 250, bolt, f150, fit, ford, pattern, rim, rims, saleen, truck, wheels
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
