Bad injectors?
IAT is near #1 if its not a CA emissions truck. Could be what your seeing
http://www.fordfuelinjection.com/?p=29 this one ?
Have you checked the contacts on the distributor, and the rotor button? If they are badly worn out, or have alot of corrosion, That may cause poor ignition. Which could possibly foul out the plugs.
Have you pulled codes ? You do know my first post about the Temp sensor was a guess based of symptoms you were reporting. I was not shocked to find, you found, it not hooked up. BUT~ Again I only took a shot in the dark at where Id look if the codes didnt work for some reason.
Ford Truck Enthusiasts Forums - View Single Post - Bad injectors?
We need codes! Codes are your friend. Buy yourself a meter if the paperclip method doesn't work for you ($30). Also it's a good time to replace your plug wires, and double check their routing/firing order. Can't help you with the oil pressure problem, havn't had to dig into it yet. And pop your specs in your sig so you don't have to list it every time you start a thread.
-Mike
-Mike
is300wrx
2004 - 2008 F150
25
09-18-2006 12:13 PM
