A4OD Tranny problems
Sorry it is a E4OD not a A4od
I have a 1993 F250 which is doing the following:
Not shifting into overdrive either with the switch or by itself
stalling when putting into reverse
shifting hard from first to second (this problem goes away if I disconnect battery and reset the computer)
I was doing a tune up by replacing the plugs, wires, cap and rotor when this problem started.
Any ideas or help would be greatfully appericated
Had the tranny coded but no codes came up however once I got it home I dropped the pan and the filter was down a bit and there was a build up in the pan on the magnet in the bottom. Put new filter and fluid and it seems to be running fine. I need to have the tranny looked at I think for the build up on the magnet
horsepower
01-22-2002 11:59 AM
