New Member: Help with Rear Wiper Motor Wiring - Ford Truck Enthusiasts Forums
Old 10-15-2011, 10:48 PM
fuzzword fuzzword is offline
fuzzword is starting off with a positive reputation.
First hi to everyone!
I would like to ask assistance regarding replacing my rear wiper motor for my 2002 Ford Explorer xlt (motocraft wm553). The color of the wires is different from the truck. Anyone has suggestions? Wiring diagram perhaps. Thanks in advance.
Old 10-16-2011, 12:20 AM
shorod's Avatar
shorod shorod is offline
shorod has a very good reputation on FTE.shorod has a very good reputation on FTE.shorod has a very good reputation on FTE.shorod has a very good reputation on FTE.
Welcome to the forum!
If you send me a Private Message with the request AND and e-mail address for you, I'll send you the wiring diagram.
-Rod
Old 10-16-2011, 10:53 AM
-Rod
Thank you for the quick response. I posted a visitor message with my email. Rep added.
Old 10-16-2011, 07:07 PM
shorod's Avatar
Thanks for the Rep. The files should be in your inbox.
Good luck!
-Rod
Old 10-18-2011, 11:29 PM
Just an update. The wires are not the same color on the vehicle and motor (my mechanic took out the connector so we have to connect the wires directly). Not sure why because I even entered my Vin # and ordered thru motocraft for the rear motor. Anyway, we tried different combinations to connect the wires but the wiper still runs even when the switch is on OFF position..
Old 10-19-2011, 07:37 AM
shorod's Avatar
Have you tried confirming the functions of the wires using either a multimeter or a test light? For example, does the wire that should be White/Orange only have voltage to it with the switch in the "On" position? Based on your description, it sounds like it will have power all the time. The next thing to check would be to pull the rear wiper relay from the rear auxiliary junction box and check for ground to terminal 2 which should have a light green wire to it. It would correspond to either relay pin 86 or 85. If you have ground to that terminal when the rear wiper switch is in On and Off, then the GEM is telling the relay to close all the time to power the rear wiper. If the ground seems to be switched appropriately (Ground with the switch in "On" and open circuit when the switch is "Off") the relay is the likely culprit.
If the signal from the GEM to the relay is grounded all the time, before condemning the GEM you'll need to confirm the signals from the switch to the GEM are correct.
Also, what is the build date of your Explorer? How many wires did your old motor have, and how many does the new have? The "Early build" 2002 Explorers apparently have a 3 wire wiper motor while the "Late build" units have a 4-wire microprocessor controlled motor assembly.
-Rod
Old 10-19-2011, 08:54 PM
-Rod
March so it will most likely an early build. I also entered my Vin number so they should not make a mistake sending the right part. 3 wires. I'll have my mechanic look at your suggestion. Thank you for all the help. I'll let you know if ever if ever we get to figure it out.
Wiper wiring RIKIL 1987 - 1996 F150 & Larger F-Series Trucks 2 05-01-2015 11:06 AM
another rear wiper inop wtroger 1997-2006 Expedition & Navigator 8 08-15-2014 11:25 AM
Rear Wiper Motor 2000 Expedition usz 1997-2006 Expedition & Navigator 15 12-23-2010 04:43 PM
Picture of rear wiper mechanism? bigshotsho93 1997-2006 Expedition & Navigator 4 08-21-2009 02:37 PM
Rear wiper not working dcicc50 1997-2006 Expedition & Navigator 6 02-06-2009 05:34 PM
Tags
1995, 2002, ajb, circuit, diagram, expedition, explorer, ford, location, motor, rear, replace, troubleshooting, wiper, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
