54 F100 build progress report OR don't look if you hate Chevy stuff on a F100
Old 05-20-2014, 03:03 PM
Bluey Zedoff's Avatar
Bluey Zedoff
Bluey Zedoff is offline
That decking is a top idea! Maintenance free! Love what you are doing.
  #107
Old 10-10-2014, 08:26 PM
das54's Avatar
das54
das54 is offline
Drove to Medford a month ago to help my in-laws move into a care home and haul a bunch of their stuff home. That's 500 miles round trip. It was hot so might need to add AC to the list of future projects, Also, the rear tires rub the bed walls when going around curves so I need to add 1/2" spacer plates and somehow take some of the slop out of the rear shackles.
  #108
Old 10-10-2014, 09:12 PM
das54's Avatar
das54
das54 is offline
Today I bought a new battery and I'm so pleased with how this turned out. Background - for years I've always had at least one vehicle parked. Usually it's the suburban except in the summer when I go camping and need it to pull the trailer. This summer I've had to replace all my car batteries, the Suburban being the most recent but the standard group 75 or 78 battery looks kind of whimpy. The counter guy at the parts store said a group 31 fits in his burb and it's more powerful and cost less. Now I just happened to put a plastic battery tray in my 54 that is big enough for this battery and when I got it home it just barely fit in under both the lower and upper stay rods. Cool.
  #109
Old 10-10-2014, 09:24 PM
topmoo's Avatar
topmoo
topmoo is offline
Nice! Great to see your truck working and making the long trip. I am jealous! One day I will be doing the same, just have to finish this huge job that I am on...
  #110
Old 10-11-2014, 12:55 AM
das54's Avatar
das54
das54 is offline
keep at it topmoo. It's a lot of fun. Everyone loves an old truck. No one comments or notices when I drive my 09 Malibu. But all kinds of people turn on their heals to see my old truck drive by and it isn't even all that good look'n.
  #111
Old 11-28-2015, 10:43 PM
das54's Avatar
das54
das54 is offline
Started Rebuild Part B. The old engine and tranny are just that - old. They were place holders first time around. Part B will include a rebuilt engine and tranny, new radiator, rebuilt steering box, maybe all new ball joints, and AC. The toughest part will be fitting exhaust headers. Really hoping this one won't take 10 years.
  #112
Old 11-28-2015, 10:56 PM
das54's Avatar
das54
das54 is offline
engine rebuild will be a vortec roller lifter block, stock vortec heads, Speed pro H631CP30 6cc flat top pistons, Howards 110235-12 cam, Edelbrock 2116 intake manifold, and exhaust headers if I can modify these to fit between the massive Chrysler steering box and the passenger side frame rail.
  #113
Old 11-28-2015, 11:19 PM
Schuyles's Avatar
Schuyles
Schuyles is offline
Sweet. Good to see you've been out enjoying it enough to know what you want to update!
  #114
Old 01-03-2016, 10:36 PM
das54's Avatar
das54
das54 is offline
easy to make negative progress. Hopefully it is simply one step back before 2 steps forward.
  #115
Old 01-04-2016, 02:18 AM
AXracer's Avatar
AXracer
AXracer is offline
Your steering box is on the pass side??? Sanderson block hugger headers are very compact, and if they don't fit they will modify or build you a custom set that will. Sanderson's are a little more expensive than the ebay junk, but well worth it.
  #116
Old 01-04-2016, 12:00 PM
das54's Avatar
das54
das54 is offline
I have a Cordoba IFS. It has a huge steering box (on the drivers side) behind the cross member and therefore located about halfway back on the engine. Most block hugger headers dump out straight down below the center ports so they won't work on the drivers side. The parallel torsion bars are another obstacle. What I need is Custom Header Fabrication - Stainless Headers Mfg., Inc.. But I'm on a really tight budget. Maybe I should go buy a powerball ticket.
  #117
Old 01-05-2016, 11:44 AM
Aloha-boy's Avatar
Aloha-boy
Aloha-boy is offline
Awesome build!
  #118
Old 01-05-2016, 06:51 PM
das54's Avatar
das54
das54 is offline
Your steering box is on the pass side??? . . . .
duh, now I get the comment. I guess that is what I said in my 11-28 post but now I can;t change it. Anyway, it's tight on both sides. The cheapo headers interfere with the steering box by about 1 inch and the passenger frame rail by about 1.5 inches. I've bent the passenger side enough to clear and that was the tough side so I feel ok about doing the drivers side. Maybe I should of tried the more expensive block huggers but I didn't want to experiment with bending them and didn't want to mess with sending them back if they didn't fit. I'm pretty sure these cheapo headers will have more than enough flow for the build I'm working on even with the kinks from bending them and the stainless pipe will look tons better than the oem cast iron manifolds.
  #119
Old 01-11-2016, 12:12 AM
das54's Avatar
das54
das54 is offline
more progress - dismantling the front suspension and got the block and heads back from the machine shop. Hmm, to buy cheap knockoff ball joints or name brand. The name brand are over twice as much. For those considering going with a new MII system vs. a used IFS, you've heard this here before but consider this, replacing the steering box and all the ball joints and bushings on a Cordoba front suspension is a little north of $400.
  #120
Old 01-11-2016, 12:29 AM
das54's Avatar
das54
das54 is offline
I scored today. I got an email this week advertising 40% off this week at PickNPull. Except my yard is 70% off because it flooded 2 weeks ago - but no returns - no warranty. And today it was sunny 45 degrees and it hasn't rained for a week so the flood has receded. Anyway, I've decided to go with a later model serpentine belt set up with AC compressor on the passenger side for the vortec head roller cam Chevy 350 that I building. I got all the brackets and pulleys for $15. Also got a 2nd ebrake cable for the ford 8.8 rear end.
Quick Reply: 54 F100 build progress report OR don't look if you hate Chevy stuff on a F100
