Heater control valve location - Ford Truck Enthusiasts Forums
Old 10-15-2011, 01:02 PM
koldleblue's Avatar
koldleblue koldleblue is offline
koldleblue is starting off with a positive reputation.
Question Heater control valve location
89 f250 5.8 heavy duty 4x4
Where is the heater control valve i think it is stuck open because when tune the temp to cool it still blows hot air not cool air from outside. seems as if the heater is always on.
I know my A/C dose not work but still should blow cool air out from the vent position right?
Thanks in advance!!!
Old 10-15-2011, 02:16 PM
White 97 xlt's Avatar
White 97 xlt White 97 xlt is online now
White 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputation
If your application uses a control valve, I'm not 100% sure if the 89 does, it will be in one of the heater hoses between the engine and firewall where the heater hoses go inside the truck..
I know the later trucks don't use a water control valve, they use a "blend door" to route the air through or around the heater core.
Old 10-15-2011, 03:51 PM
Conanski's Avatar
Conanski Conanski is online now
Conanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud of
There is no control valve on this vintage truck it's all done with the blend door and it sounds like yours is stuck closed.. which is uncommon. The door is controlled by engine vacuum and to get to it you first remove the glove box and then the heater core cover and it should be visible.
Old 10-15-2011, 03:57 PM
Hey Paul, does the 89 have the issue of the white vacuum line that goes bad like the 90's do?
Another quick question. If the vacuum is lost, does the blend door default to heat or cool? Or does it just stray where it was the last time there was vacuum?
Old 10-15-2011, 04:11 PM
EPNCSU2006's Avatar
EPNCSU2006 EPNCSU2006 is offline
EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.
I thought the temperature control was operated by cable and only the fresh air door and vent selector were vacuum operated.
My '87 uses a cable for both the temperature control and vent position selector, but uses vacuum to control the fresh air door - I know that changed, but I'm not sure in what year.
Old 10-15-2011, 04:21 PM
Conanski's Avatar
'89 and '90 trucks should be the same though we know how that goes.
I know there is at least one vacuum actuated device in the heating system on these trucks but I couldn't tell you with 100% certainty what it is now, but in any case I bet the OP's problem is with either the vacuum or cable operated components inside the heater box... or with the controls themselves.
Heater trouble, please help. gunshack 1997-2006 Expedition & Navigator 3 09-26-2016 03:07 PM
Heater Control Valve Macs1964F100 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 11 06-14-2014 09:17 PM
heater blows cold air JP Hobbit 1997 - 2003 F150 5 10-10-2012 08:27 AM
6.0 diesel-Interior heat fades in and out 2longg 1999 to 2016 Super Duty 12 11-10-2011 10:15 PM
2005 heater problem dlgfords 1997-2006 Expedition & Navigator 0 10-19-2011 10:35 PM
Tags
1997, 2002, 97, check, control, controls, expedition, f150, f250, ford, heater, heatercontrol, location, valve, vaule, xlt
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
