oil leak from oil filter housing need info
Old 10-15-2011, 09:33 AM
poormansdvd's Avatar
poormansdvd
poormansdvd is offline
Question oil leak from oil filter housing need info
f250 super duty triton V8 5.4 L 4X4
found oil leak on the housing itself several pin holes just out side where the filter gasket seals.
upon looking at it seems pretty tough job.
so my question is can the oil filter housing be replace without pulling the motor or can i just remove the engine mounting brackets and then the housing or is there more to it and where could i possible find detailed instructions on how to do this my self
and where do i find a new one?
or is it just a dealership item?
or could i just pb weld it ?
Old 10-15-2011, 09:15 PM
galaxie641's Avatar
galaxie641
galaxie641 is offline
If it is on the front D. side of the engine like mine it can all be done with the engine in. I'll assume a SD has just as much if not more room than my F150, Rockauto should have everything you need. It will be far easier with the inner fender flap removed. Hardest time I had was with the top and bottom bolts, very little room to get to them but it can be done and with a very small movement of the wrench.
Old 10-15-2011, 10:05 PM
LxMan1's Avatar
LxMan1
LxMan1 is offline
I replaced the gasket on on in a 93 MarkVIII which is much tighter than a truck so it shouldn't be too hard. Can't even hardly get to the filter in that chassis.
Old 10-24-2011, 04:29 PM
poormansdvd
after some research
after some research all i need to replace is the oil cooler adapter part number 6a642
what i would like to know what do i have to do to get it off would it un screw like an oil filter or is it locked in some way?
http://s1083.photobucket.com/albums/j400/poormansdvd/ i tried to add picture but doesn't look like it worked so if it didnt you could click on the link above to see exactly what i need to replace
Last edited by poormansdvd; 10-24-2011 at 04:32 PM. Reason: tried to add picture but looked like it didnt
Old 11-02-2011, 04:10 PM
poormansdvd
easy repair
after removing oil filter all i needed was a 9/16 allen wrench to remove oil cooler assy. ant the two anti-freeze hoses that was the hard part now im try to find a replacement part seams to be a dealer only item cept im trying to find one on line
any idea how to find one i think i found one but they cannt garuntee me its what i need for some reason heres the link to what i think will work can any confirm or reject this
here the link to the one i found l
Restoring American History
Old 11-09-2011, 07:01 PM
poormansdvd
wrong part
doesnt fit to small
Old 08-02-2018, 09:27 PM
Zachery Smileys's Avatar
Zachery Smileys
Zachery Smileys is offline
Oil leak need help?
Got a 04 f-150 with the 5.4 triton an I’ve got a oil leak on driver side of motor. I think it’s coming from oil filter housing but not sure. I got my oil changed on 6-30-18 at 124,483 miles an I checked the oil today 8-2-18 at 125,555 An it’s at the add mark. I’ve tightened all the oil pan bolts oil filter housing bolts an oil filter itself an still leaking oil. I was wondering if anyone has had this problem? If so what was it an how’d you fix it?? Thanks
Old 08-02-2018, 09:44 PM
z31freakify's Avatar
z31freakify
z31freakify is online now
Received 1,188 Likes on 816 Posts
Check exactly where the oil leak is comming from, clean the engine real good and avoid getting the COP wet.
quakerj
11-17-2013 04:57 PM
proline69
1999 to 2016 Super Duty
01-12-2011 03:24 PM
AndeyHall
09-27-2010 08:17 PM
heatwave
1997 - 2003 F150
07-19-2009 10:54 PM
crew02
29
02-02-2008 01:21 PM
Quick Reply: oil leak from oil filter housing need info
