You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
06 PSD 6.0 4x4 about 70,000 miles air intake and exhaust. We were recently pulling our toy hauler when temp spike, return to normal in 20 sec, let it cool puked out about a gallon of coolant. Drove home 30 min into drive on flat ground got a check engine light with wrench light and limped her home. Took her to a dealership and they started diagnostic test said the found an over boost code, and the headgasket was damaged which pressurized the coolant tank after further investigation they said the turbo was the cause of the damage and they wouldnt honor extended warranty.they also said the center section of the turbo was frozen. I never lost boost. PLEASE HELP this doesnt make any sense.
The diagnosis seems plausible. But I'm not clear on why they are denying warranty coverage. Your turbo should be covered. However, the aftermarket intake might be what they are laying this on. Unfortunately, if they want to be *********, they probably got you on that. Even though I don't believe it caused this problem, and those turbos are known to gunk up and stick.
If I was paying the bill, I would pull it out of a Ford shop and get an independent second opinion.
__________________
Folks call me Bill. Why, yes, it is a 6 liter. Your jealousy is showing.
2006 F250 XLT SCLB FX4 4x4 6.0L Auto,Magnaflow Turbo Back (w/CAT),Edge Insight CS,Blue Spring,RhinoLiner,Retrax Cover,Cab Lights Retro-fit,Overhead Console Retro-fit,Bilsteins,Harpooned,C-Betrs,Fumoto,'08 Diff Cover,Upfitters Retro-fit,Coolant Filter,Custom Man Steps,Keystone 2011 Cougar 278RKSWE,2012 Fusion SE
