NON-OEM oil cap vs OEM
So now that I have two trucks to compare side by side I noticed something on the last oil change on both trucks.
One had a WIX oil cap on it, which is noticeably taller. Eyeballing it I would say 1/2" or so maybe?
Soon as I saw this I ordered an OEM online and got it installed today.
All I could think about was the filter not sitting tight inside and letting un-filtered oil bypass it as it wiggled up and down with the extra room inside the cap.
Does that sound like what would be happening inside with the incorrect cap on?
I say this because I had two injectors go not to far apart from each other on the truck with the WIX cap on it...dirty oil getting by the filter and into the injectors...and I know how the 6.0's like clean oil!!! Any correlation between the filter and injectors you think?
BTW, I already know to run all OEM oil/fuel filters and do nothing but!
So for the rambling ...just has been on my mind
I bought my 2006 three years ago and have changed oil religiously (Rotella T6), and ensured that I used Motorcraft fuel and oil filters every time. But last month when I was working on the oil cooler and egr cooler, I realized that my oil cap said NAPA Gold on top of it, and I was steamed. I immediately ordered an OEM cap and it has since been installed. No telling how much damage was caused to my injectors over the last three years (and however long the previous owner had driven it that way). This truck should *not* be this easy to break. </rant>
Don't get me wrong - I love my truck. Just that I've learned about a whole lot of little "gotchas" in the last couple of months, even after thinking that I had educated myself and mostly done it all right over the last 3 years.
You make a good point, however, the 6.0 is the most finicky drivetrain that I've ever met when it comes to "must use OEM parts only".
Josh
Just what I thought.
Make me sick knowing how long this went on for, (bought the truck last year, one owner)
Possibly a $23.00 cap could have saved 2 injectors : (
BTW, also doing the blue spring upgrade on both trucks too after reading on up on it!!
