Holy Improvement, Bat Man!
As some of you know, I have a 79 F150 4x4, 300, 4 speed M/T that I bought for $1K. She runs great, but man, it took a little while to adjust to how flat-out slow it was.
Enter the new Flowmaster Super 44.
Wow. Now granted, my old exhaust was a corroded pipe to a worn out muffler to nothing. Now I have a new pipe to Super 44 (2.25" on both ends) to pipe dumping out at rear wheel. I cannot believe the improvement I got for putting $100 into this thing. Better acceleration off the line, lower cruising RPM's at 60mph and I'm assuming I'm getting better MPG.
A great improvement for us six-shooters!
on
Lower cruising rpms with an exhaust change? Explain that one,
With an all-out race vehicle you as much free flow as you can get(but a certain amount of back pressure is still required) but in a street vehicle you need the correct balance of back pressure.
His comments and experience does not surprise me.
on
This is what I was getting at. I don't care if it makes 1hp or 1000hp, if the rest of the drivetrain is unchanged, you will still be running the same rpm at 60mph with a manual trans. Automatic is a slightly different story with T/C slippage.
quehele
02-02-2006 10:32 AM
