TCC soleniod code P1740 - Ford Truck Enthusiasts Forums
Old 10-14-2011, 10:43 AM
Tony Froelich Tony Froelich is offline
Tony Froelich is starting off with a positive reputation.
On my E250 this code came up yesterday. Does anyone know exactly where it is? can it be accessed from the Pan?
Thanks
Old 10-14-2011, 06:39 PM
projectSHO89 projectSHO89 is offline
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
The code indicates a fault in the electrical circuit for the TCC solenoid. It does not mean the the TCC solenoid is the only possible cause for the code.
The solenoid (or the solenoid pack) is accessible from the pan.
Old 10-16-2011, 10:08 AM
TCC code 1740
Well I'm thinking it must be electrical because the transmission seems to be shifting just fine. I do not have the classic symtoms of losing overdrive or engine stalling when shifting to third. Any Ideas on what else it could be?
Thanks
Old 10-16-2011, 09:27 PM
Bluegrass 7 Bluegrass 7 is offline
Bluegrass 7 has a good reputation on FTE.Bluegrass 7 has a good reputation on FTE.Bluegrass 7 has a good reputation on FTE.
Tony, your going beyond what you need to know.
Look up the code so you see exactly what it's telling you.
The computer looks at the DC Current operating 'kick' called a "signiture".
It's out of limits.
It does not mean the Torque converter is not working but there is a detected issue for possible pending failure.
This is why the code is available as an early indicator so more serious damage can be avoided from overheating the transmission running out of lock and OD..
It could be the solenoid, the flat cable feeding it or a harness feeding from the outside. Might be a ground or a cross. It's not open or it would not work at all.
Project gave you the basic scoop to go with. There are no other 'ideas' to get.
Pull apart the connector on the outside first to see if water has caused a cross or resistance ground, then and try to detect a fault looking in with a resistance meter before taking things apart so you have an idea what your next move is.
I could give you lead info but it's on a Windows XP machine so my program does not work on Windows 7 until I get a monitor switch so I can see both machines at the same time.
Good luck.
Old 02-28-2012, 10:55 PM
04mudslinger 04mudslinger is offline
04mudslinger is starting off with a positive reputation.
It's out of limits.
This is why the code is available as an early indicator so more serious damage can be avoided from overheat5ing the transmission runnin out of lock and OD..
Good luck.
Did you get the monitor switch you refer to? I could use the lead info. I got this code a while back and cleared it. Now it's back. My next step is to check the outside connector. When the code showed up previously, I could tell I had harder downshifts, but now the upshift from 2 to 3 is the only noticeable harder shift now.
Codes kbf1961 6.0L Power Stroke Diesel 7 10-17-2015 11:05 PM
Color Code tlcsr66 Excursion - King of SUVs 1 05-14-2014 05:08 PM
S code spring trucktech Excursion - King of SUVs 1 07-12-2012 03:09 PM
Axle Codes 1972RedNeck 1973 - 1979 F-100 & Larger F-Series Trucks 7 05-31-2012 12:33 AM
Reading the ABS Error Codes wolfmanagh Explorer, Sport Trac, Mountaineer & Aviator 4 04-29-2011 07:56 AM
Tags
150, 2001, 2005, 2008, code, excursion, f150, fault, ford, fordfaultcodep1740, location, p1740, ranger, solenoid, taurus, tcc
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
