GPR LED Light - Ford Truck Enthusiasts Forums
GPR LED Light
Old 10-13-2011, 06:56 PM
fordtruck661 fordtruck661 is offline
fordtruck661 is gaining momentum as a positive member of FTE.
GPR LED Light
Hi guys Im trying to put in a LED for my GPR I have all my wire run and have put in my led light and it does not work! I dont know why here is the led i used 110VAC Red Neon Lamp Indicator - RadioShack.com I alos put a 1/2 amp fuse on the end of it.
Old 10-13-2011, 06:57 PM
SpringerPop's Avatar
SpringerPop SpringerPop is online now
Too old to be too smart..
SpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputation
Wrong LED.
You have one for 110 volts.
Our trucks are 12 volts.
The one you have has a different value built-in current-limiting resistor.
Pop
Old 10-13-2011, 07:10 PM
Quote:
Originally Posted by SpringerPop View Post
Wrong LED.
Pop
Ok does anyone know what led I should be getting then
Old 10-13-2011, 07:27 PM
honeydew honeydew is offline
honeydew has a very good reputation on FTE.honeydew has a very good reputation on FTE.honeydew has a very good reputation on FTE.honeydew has a very good reputation on FTE.
I ordered the ones linked below and used one of the green ones. Easy install, just press fit into a 5/32" hole in the dash surround adjacent to the WTS light.
5/32" LED Dash Indicator Lights Set (2 Green & 1 Red) | eBay
Old 10-13-2011, 08:01 PM
JamesHajek's Avatar
JamesHajek JamesHajek is offline
JamesHajek is gaining momentum as a positive member of FTE.JamesHajek is gaining momentum as a positive member of FTE.
Green LED with Holder - RadioShack.com
You were pretty close...
Part # for the red one is 276-0270
Old 10-13-2011, 08:04 PM
Ponyboychris's Avatar
Ponyboychris Ponyboychris is offline
Hit it!
Ponyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud of
This is the Radio Shack LED you need. Part # 276-0270 (Red LED) - they also come in green and amber.
Red LED with Holder - RadioShack.com
Old 10-13-2011, 08:05 PM
At this point i will be happy if the size of the hole are the same
Old 10-13-2011, 08:16 PM
JamesHajek's Avatar
Quote:
I'd love to tell you it will, but I think the one I told you was 5mm and the one you drilled for was almost half an inch..
Old 10-25-2011, 05:56 PM
I thought I would finish this off and say I got the right light and it was way to small for the hole I had already drilled. So I ended up having to cut the light bulb out of the right light and soldering it into the first light I had. So in the end I got everything to work but made LOTS more work for my self all over and dumb mistake I made. Some times you just have to LOL at yourself!
Old 10-25-2011, 07:55 PM
KJNDIVER's Avatar
KJNDIVER KJNDIVER is offline
KJNDIVER has a very good reputation on FTE.KJNDIVER has a very good reputation on FTE.KJNDIVER has a very good reputation on FTE.
Got a picture of said handywork and where you mounted it? We like truck **** in these parts.
Old 10-25-2011, 11:20 PM
CSIPSD's Avatar
CSIPSD CSIPSD is offline
CSIPSD is a splendid one to beholdCSIPSD is a splendid one to beholdCSIPSD is a splendid one to beholdCSIPSD is a splendid one to beholdCSIPSD is a splendid one to beholdCSIPSD is a splendid one to beholdCSIPSD is a splendid one to behold
There always seems to be some confusion about the glow plug system and the wait to start light on the 7.3l Powerstroke. The Wait to start light is controled by the PCM, but has little if anything to do with the operation of the glow plug system. It is more of a timed idiot light then anything. Also, just because the WTS light comes on, this does not mean that the glow plugs or glow plug relay is working.
So a lot of guys install a glow plug warning LED (GPR-LED)...
Here is a quick video that shows the difference between the WTS light and the time that the glow plugs stay on...
YouTube - Glow plug light
To install this LED is very easy, even the most novice electrical guy can handle this in your driveway in about 30 minutes...
First go to your local autozone, Radio Shack or Napa and pick up some 12-14g wire, about 10' is more then enough, and a LED of your choice. They have tons of different kinds, sizes and colors but get one that is a complete unit to make this easy, not one that requires a Diode or Resistor...
Once you are home again pop the hood and locate the Glow Plug Relay (GPR)... It is the furthest back relay if you have a 99.5 and up. Take a look at this picture so you understand the different posts on it...
You want to run a wire from the #4 post into the cab and to where ever you want to install the LED, add a small fuse to this line before you go to the cab (I have not done this, but its good practice).
There is my Red wire for the GPR-LED headed to the cab and up the A-pillar.
For your ground wire, depending on where you install the LED, you can ground it with your gauges, to any metal in the cab or back to the battery (waste for sure!!!)...
Now when ever you turn the key on, and the glow plug relay closes, this light will light up. If your having hard start issues and this is not coming on, well you know your relay is bad... If your having hard start issues and this light is coming on, then you know its not the relay...
Feel free to hit me up with any questions...
Old 10-25-2011, 11:55 PM
OK, now all we need is an article about how to use an (on)-off-on rocker switch to auto/manually control the operation of the GPR.
Pop
Old 03-15-2012, 12:05 PM
Backdraft-14's Avatar
Backdraft-14 Backdraft-14 is offline
Backdraft-14 is gaining momentum as a positive member of FTE.
I installed the 4 gauge pod w/ GPR led from riffraff. After getting everything wired in the GPR led does not turn off, checked the GPR 12 Volts to the constant hot terminal 12 volts to small terminal left (counter clock wise) 4.46 volts to large terminal with LED hooked up, 9.86 volts with LED unhooked, and 0.00 volts to small terminal. Ground for the pod and the LED is a factory ground under dash.
Edit: Oh ya this would be KOEO
With KO power to constant hot only.
I also purchased a Stancor GPR and am having the same problem, reason for purchase (Does there have to be one? LOL)
Robert
Old 03-15-2012, 03:28 PM
Update: Tested the the blue wire that is fused and it is reading .75 volts Key off and 9.18 volts KOEO, the wire was not connected to the relay during testing. Is this wire supposed to have voltage with it not connected?
Another test hooked up the power wire and the 2 small terminal wires hooked up the LED wire KOEO no light, tried grounding the relay to click over nothing.
Any suggestions?
Old 03-15-2012, 04:03 PM
The wire going to the led has so be on the large terminal closest to the fire wall. This terminal should not have any power when the truck is off
gpr leads timmyboy76 1999 - 2003 7.3L Power Stroke Diesel 25 12-05-2016 03:40 AM
2012 Super Duty LED Lights and Custom Switches Supereco06 1999 to 2016 Super Duty 5 01-01-2014 10:07 AM
AIH delete with one GPR and GPCM Backdraft-14 1999 - 2003 7.3L Power Stroke Diesel 4 03-17-2012 05:16 PM
Interior Green to Blue LED "how-to" w/pics mikeyc0120 1999 - 2003 7.3L Power Stroke Diesel 152 11-09-2010 10:05 PM
hard start? Here's how to check your GPR bdrummonds 1999 - 2003 7.3L Power Stroke Diesel 20 12-20-2008 01:41 PM
Tags
532, 73, bypassing, dash, ford, glowplug, gpr, indicator, led, led2760270resistor, leds, powerstroke, radio, red, relay, shack, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
