You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
If you are willing to drop some $$$, I would go for some good LED bulbs. The cheap ones are dimmer than halogens, but V-Leds have great products. The output will be higher and the instant on-off is alot more luxurious
Where did you purchase your led's? I tried some a while ago and threw them away as they were really bad.
V-Leds has one of the best quality products on the market V-LEDS.COM | LED Dome, Map, License Plate, Reverse, DRL, Turn Signal, Brake Lights
they have the switchback led's which are pretty cool, their white all the time but blink yellow when u turn on the blinker. They also have normal LED replacements. Regarding mine, I always make my own bulbs with the brightest emmiters available. On my infiniti I put 6 3Watt LED's for example.
That and there is also the option to use a controller. High quality LEDs plus a controller will make them "holy effing shizer" bright when you hit the brakes. What the controller does is switch them off/on really fast so they appear to be on constantly when you just have the lights on with no brakes applied, just dimmer than they are when on full blast. Then when you hit the brakes the controller kicks off and they go full bright. I saw a guy do this with an older SHO Taurus but I can't find the thread...
