Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > 6.2L V8
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
6.2L V8 Discuss the 6.2L V8 SPONSORED BY:
  #1 (permalink)
Old 10-13-2011, 12:25 PM
RAPR's Avatar
RAPR RAPR is offline
2011 Ford F-250
RAPR is starting off with a positive reputation.
RAPR
6" suspension lift problem with 2011 f250 6.2 engine
I am new to this forum and have one heck of a question to ask to start off. I currently have a 2011 crewcab shortbox 4x4 f250 with the new 6.2 gas motor. I was interested in getting a Fabtech 6" suspension system installed on the truck and run 35" tires, but I ran into a dilemma.
According to Fabtech, when putting on this size lift, it will cause the front driveshaft (for the front driveline) to interfere with the catalytic converter coming off the left side of the engine. Fabtech's recommendation is to replace the factory driveshaft with a shaft with a smaller diameter....well I'm not too fond of that option.
I was thinking that since I plan on putting a Corsa Catback exhaust system on the truck in the near future, why not go head and install "Hi Flow" catalytic converters that is smaller in size, compared to OEM, to alleviate the driveshaft/converter problem. After talking with a muffler place, they said that Ford trucks' O2 monitoring system will likely throw a check engine light if I change the converters. From there, the only was to get rid of the check engine light would be to use a programmer....and i don't want to use a programmer "yet", until my factory drivetrain warranty runs out.
Has anyone else run into this problem yet, or does anyone have any suggestions?? Help would be GREATLY appreciated.
  #2 (permalink)
Old 10-13-2011, 02:41 PM
kmonty2's Avatar
kmonty2 kmonty2 is offline
2011 Ford F-250
kmonty2 is gaining momentum as a positive member of FTE.kmonty2 is gaining momentum as a positive member of FTE.
kmonty
I think the programmer would be the least of your warranty issues with all the other stuff you plan on doing. New exhaust, change the converters, 6" lift, and 35" tires. Sounds like there is a lot of things that Ford could blame a issue on other then a new program i nthe computer. Just my 2 cents.
__________________
Kevin
2011 F-250 CC, 6.2 Gas, 3.73, 4x4 w/FX4, Tuxedo Black, Steel Cloth interior,Goodyear Wrangler Duratrac's, Air Aid Intake, Bilstein 5100 shocks, Hellwig adjustable sway bar, 5 Star Tuned, Line X bed liner, X Tang Tri-Fold bed cover.
  #3 (permalink)
Old 10-13-2011, 03:06 PM
RAPR's Avatar
2011 Ford F-250
RAPR
I don't see a Catback exhaust system or a 6" suspension lift voiding the warranty of the transmission or the engine itself...per The Magnuson-Noss Act. Those two mods shouldn't affect the transmission directly, and the catback couldn't do any harm to the engine. Ford could, however, point out that a programmer could cause problems with the transmission and engine by using overly aggressive shifting programs and running a engine too lean/allow engine to knock. A lift should only void the warranty on the transfer case and drive shaft...every other part affect by this lift would probably be considered a "wear" item and not covered under a drivetrain warranty anyways.
  #4 (permalink)
Old 10-13-2011, 03:14 PM
2000silverbullet's Avatar
2000silverbullet 2000silverbullet is offline
2011 Ford F-350
2000silverbullet is a name known to all2000silverbullet is a name known to all2000silverbullet is a name known to all2000silverbullet is a name known to all2000silverbullet is a name known to all2000silverbullet is a name known to all
You may be already aware, but you can clear 35's with a leveling kit, or if you're looking for more clearance, a 4.5" lift. That may alleviate the driveshaft issue entirely. Those 35's are gonna look tiny under that much lift.
This is the first I'm hearing of this specific issue but the majority of the lifted 2011+ SD's I've seen pics of have been diesels.
Welcome to FTE!
__________________
Matt
2011 F350 - 6.2 CC, LB, 4.30s, Lariat Ultimate pkg, FX4, Amp steps, Lockpick, AC LC6i, JL HD900/5, JL 13TW5, JL C5-570's, Bilstein 7100 stabilizer, Rancho RS9000XL's, Leveled w/ 35" Toyo M/T's and 5 Star tuned
**Sold - 2000 F250 V10, 6.5" Pro Comp, 37" Toyo MT's
  #5 (permalink)
Old 10-13-2011, 05:22 PM
RAPR's Avatar
2011 Ford F-250
RAPR
I hope it doesn't look goofy with 35" tires. I was wanting to go with the 295/70/18 Terra Grapplers b/c that is the biggest Terra Grappler they make for the desired load rating (on 18" rim). If its going to look goofy, I'd rather just go with a 4" Fabtech
  #6 (permalink)
Old 10-13-2011, 05:44 PM
2011 Ford F-350
It'll look goofy with that much lift and 35's......my opinion of course. Plus if you can avoid driveline issues by dropping it a couple inches, it'd be worth it.
__________________
Matt
  #7 (permalink)
Old 10-13-2011, 06:00 PM
RAPR's Avatar
2011 Ford F-250
RAPR
the reason why I thought 35" would look "ok" on a 6" lift is bc on Fabtech's website, it suggest the use of 35" tires with their 4" or 6" lift....as seen on the following link:
Products > FORD 4WD > F250 2008-11
  #8 (permalink)
Old 10-16-2011, 08:18 PM
socapots socapots is offline
Garage is empty, add now
socapots is starting off with a positive reputation.
didnt see any pictures there. Google time..
edit: i suck at google. lol.
__________________
2011 F250, Lariat, Crew, 6.2L
First truck and new vehicle..
Lovin every minute of it. lol.
  #9 (permalink)
Old 10-17-2011, 10:48 AM
Beech19 Beech19 is offline
Beech19 is starting off with a positive reputation.
I have 35x12.5x18 Dick Cepek Radial FC-II's on mine. No lift or leveling kit and they do not rub.
  #10 (permalink)
Old 10-19-2011, 12:10 PM
ARFFMAN82 ARFFMAN82 is offline
ARFFMAN82 is starting off with a positive reputation.
I have a 2011 F250 sc 6.2 with 355/60 20 terra grapplers on 20x12 rockstars and an 8" procomp lift and ran into the same front drive shaft hitting the cat. I took it down to the muffler shop, they cut a few inches behind the cat, and rewelded and no more rub. Its been that way for 10000 miles and a few warranty issues. Ive never had any problem with the truck or dealer and it cost me $50.
  #11 (permalink)
Old 10-21-2011, 08:01 AM
RAPR's Avatar
2011 Ford F-250
RAPR
I decided to go with a 3.5"Fx3.0"R ReadyLift kit w/ 295/70/18R Terra Grapplers. I went ahead and got a completely new 2" diameter driveshaft made, since it still would not clear the CAT completely. I decided to go with a completely new driveshaft, so if I ever do have driveline problems I can just remove the lift and replace old drive shaft and the dealer will never know. I am just way too scared to void my warranty on an engine/transmission that has only been in use for one year.
Plus, if I ever decide I want to lift the truck even more in the future, I don't have to worry about the CAT/Driveshaft issue in the future. I will post pics once I get my truck back.
  #12 (permalink)
Old 10-24-2011, 02:49 PM
RAPR's Avatar
2011 Ford F-250
RAPR
Click the image to open in full size.
  #13 (permalink)
Old 10-26-2011, 07:07 AM
Front Runner's Avatar
Front Runner Front Runner is offline
2002 Ford Excursion
Front Runner has a superb reputationFront Runner has a superb reputationFront Runner has a superb reputationFront Runner has a superb reputationFront Runner has a superb reputationFront Runner has a superb reputationFront Runner has a superb reputationFront Runner has a superb reputationFront Runner has a superb reputationFront Runner has a superb reputationFront Runner has a superb reputation
Nice truck!
__________________
2002 Excursion Limited, 4x4, V10, 4.88 gears, 6" PC lift , 20" XD Hoss wheels, 35" Pro Comp tires
2013 VW GTI 2.0L TSI, 6 speed Manual
  #14 (permalink)
Old 10-28-2011, 08:23 AM
RAPR's Avatar
2011 Ford F-250
RAPR
Thanks for the compliment!
  #15 (permalink)
Old 10-28-2011, 08:50 AM
kmonty2's Avatar
2011 Ford F-250
kmonty
Looks great, I really need to get those chrome covers for my doors. They look better each time I see them on the truck.
__________________
Kevin
Tags
2011, 37, 62, 8, drive, extend, f250, front, issues, kit, lift, lifted, photos, programmer, shaft, thread
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
