Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 1997 - 2003 F150
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1997 - 2003 F150 1997-2003 F150, 1997-1999 F250LD, 7700 & 2004 F150 Heritage SPONSORED BY:
  #1 (permalink)
Old 10-13-2011, 11:26 AM
paker paker is offline
Garage is empty, add now
paker is starting off with a positive reputation.
Question - EVAP valve operation
AFAIK, there are 2 valves, one that feeds vapor to engine and the other that seals canister from atmosphere. Let me call the first Canister Purge Valve (PV) and the latter Canister Vent Valve (VV).
1) Is Canister PV normally open? Seems to be normally closed.
2) Is Canister VV normally open? Seems to be normally open.
3) Do they run on 5V or 12V?
Thanks.
EDIT: Canister Purge Valve (or purge solenoid), normally closed. Canister Vent Valve, normally open. Both run on +12V. PCM controls ground, as usual.
__________________
97 V6 4.2L Reg Cab Long Bed
Tags
12vdc, 1977, 1996, 2000, bronco, evap, evaporator, f150, ford, open, operation, purge, ranger, taurus, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
