What's the deal with EBP sensor? - Ford Truck Enthusiasts Forums
Old 10-13-2011, 10:15 AM
Rusty Axlerod's Avatar
Rusty Axlerod Rusty Axlerod is offline
Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.
I've read recently the EBP is inferred from MAP/Baro and the sensor is ignored. I've also read of checking EBP for a few problems and even a repair. Is the flash version the difference? How do you know if strategy in the truck is reading EBP? Is it just the latest flash that has the change?
Old 10-13-2011, 10:35 AM
EXbowtieguy's Avatar
EXbowtieguy EXbowtieguy is offline
EXbowtieguy is gaining momentum as a positive member of FTE.EXbowtieguy is gaining momentum as a positive member of FTE.
Quote:
+1 on this question ?
I had mine in for the stumble issue , they tested , said my EBP was bad , replaced it , reflashed the truck....
When I asked the guy why I had to change it because it was my
Understanding that the latest flash eliminated using it.... He looked at me like I had a "Boog" hangin and collected payment ?
Old 10-13-2011, 01:55 PM
npccpartsman's Avatar
npccpartsman npccpartsman is offline
npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.
The EBP was only deleted from the strategy on the 03 engines. None of the 04 and up engines are affected.
Old 10-13-2011, 02:23 PM
Quote:
10-4 .... Thanks !!
Old 10-13-2011, 04:35 PM
Ahh. That makes sense now. Thanks!
Old 11-01-2011, 11:59 AM
j4henry j4henry is offline
j4henry is starting off with a positive reputation.
this might be a stupid question but my 2003 ex has a reflash sticker on the radiator support and if it eliminated the ebp how come when the tech hooked my truck to laptop it showed what the ebp was reading and I cleaned it up and my turbolag is gone?
Old 11-01-2011, 12:06 PM
Quote:
The EBP wasn't eliminated from the strategy until sometime in 05 IIRC so you may not have the latest calibration. What's on the sticker may be ancient but if you can read the flash level that may be some help.
Old 11-01-2011, 01:34 PM
This is the sticker
Just curious because I can't get an ebp reading on my scangauge yet dealer says it is reading
Old 11-01-2011, 01:41 PM
This is the sticker
Read this short thread: http://www.ford-trucks.com/forums/10...er-2003-a.html
According to your sticker your EBP shouldn't be working and the SGII would confirm that. I'm not sure what the capabilities of IDS are in that regard. Maybe M-Chan, Cheezit, or somebody more knowledgeable in those matters can give an explanation.
Old 11-01-2011, 03:49 PM
SixGunCaliforniaKid's Avatar
SixGunCaliforniaKid SixGunCaliforniaKid is offline
SixGunCaliforniaKid is gaining momentum as a positive member of FTE.
So if my scanguage is reading the EBP and I have a dec 03 build it more than likely (does not) have the most recent flash in it. is that an accurate statement?
Old 11-01-2011, 04:21 PM
wulfman wulfman is offline
wulfman has a great reputation on FTE.wulfman has a great reputation on FTE.wulfman has a great reputation on FTE.wulfman has a great reputation on FTE.wulfman has a great reputation on FTE.
Look my 03 has the reflash but only because when i got the RECALL in the mail like a dumb assss i took it to them and let them try they kept it for almost two weeks . First i picked it up next day and it ran like sh-t made no boost and no power, took it back and they gave me a rental and they had it for awhile . They could not get it to take the flash so then they started throwing parts at it new turbo and from what the tech told me all kinds of stuff . Finally they put a muffler on it , i had taken off the muffler and put on straight pipe. When they did that some codes showed up and they got it close, It was never the same after that not as quick as it was . I regret ever taking it in . That was at 64000.
Old 11-02-2011, 03:34 AM
carltonwebb's Avatar
carltonwebb carltonwebb is offline
carltonwebb has a great reputation on FTE.carltonwebb has a great reputation on FTE.carltonwebb has a great reputation on FTE.carltonwebb has a great reputation on FTE.
Quote:
Dangit man.....I was lighting up and laughed at the same time when I read this. If I ever stop coughing, maybe I can finish enjoying the laugh.
Old 11-02-2011, 05:39 AM
Quote:
That would be my understanding.
EBP Sensor Issues comtb 1999 - 2003 7.3L Power Stroke Diesel 3 12-31-2016 03:59 PM
Shed some light on correct EBP readings for early '04 Tampa250 6.0L Power Stroke Diesel 5 05-07-2015 07:02 PM
EBPS, Map, Baro values... alstieg 1999 - 2003 7.3L Power Stroke Diesel 4 12-14-2014 11:44 PM
EBP reading incorrect. SGorman13 1999 - 2003 7.3L Power Stroke Diesel 13 02-14-2014 04:33 PM
EBPS question Ford4Life7.3 1994.5 - 1997 7.3L Power Stroke Diesel 5 11-01-2013 12:36 PM
Tags
2000, 2005, 60, 60l, diesel, ebp, elimination, epb, excursion, f250, ford, inferred, sensor, truck, whats
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
