Vacuum seals & dust boots w/ pics - Page 2 - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 10-16-2011, 09:27 AM
Special Ed's Avatar
Special Ed Special Ed is offline
Special Ed is gaining momentum as a positive member of FTE.Special Ed is gaining momentum as a positive member of FTE.
Was thinking of something. Would the Amsoil diff fluid I just put in a month ago & the diff fluid the dealer just put in be different colors by any chance? If so that would be great then I could just finger the leaking fluid & look at the color. Probably the same gold color though?
Old 10-16-2011, 09:35 AM
Snowseeker's Avatar
Snowseeker Snowseeker is online now
Snowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputation
Dealerships do such great work...
I'd for sure take that back and make them do it again and again until they get it right.
Old 10-16-2011, 09:54 AM
Special Ed's Avatar
Oh I am snow. Was suppose to take my truck on a trip to Florida with the family for 10 days to leave yesterday. After seeing all that fluid Friday there was no way I could take it. Luckily borrowed a buddys truck to save my trip. Its a Chevrolet Silverado which I'm not a fan of, but doing the job. I'm now in Atlanta as I type. I have a knot in my throat from this.
Old 10-16-2011, 09:57 AM
99f350sd 99f350sd is offline
99f350sd has a good reputation on FTE.99f350sd has a good reputation on FTE.
Front doesn't turn unless you are in 4wd so you would have been fine road driving..
Old 10-16-2011, 11:10 AM
Special Ed's Avatar
Thanks 99f350. I see so the front driveshaft doesn't turn out of the transfer case untill you engage 4wd. Maybe I should of brought it then so I could of brought it back bone dry to them.
Old 10-23-2011, 12:41 PM
Special Ed's Avatar
Just back home from vacation. Took the truck to the store & decided to try the 4wd since the install of the new vacuum seals & dust boots. Engaged fine but when I went to switch back out to 2wd she thumped then soon as I was coasting to a stop banged a few more times & heard a little grinding sound. I was like WTF u gotta be kidding me. I have used the 4wd all summer actually every weekend pulling my boat in & out the lake. 4wd has always worked flawlessly with no noises or leaks.
Passenger side axle seal continues to leak since work performed 10/10/11.
I have cleaned the knuckle several times with brake/carb cleaner & fresh fluid continues to flow. I am about to drop her back off at the dealer today shortly soon as I can find a ride. Im pulling my hair out now with this thing. Am I entitled to a loaner as this is Fords baby? This truck is my only vehicle now as it is too cold to ride.
Old 10-23-2011, 02:56 PM
2006powerstroke90's Avatar
2006powerstroke90 2006powerstroke90 is offline
2006powerstroke90 has a great reputation on FTE.2006powerstroke90 has a great reputation on FTE.2006powerstroke90 has a great reputation on FTE.2006powerstroke90 has a great reputation on FTE.2006powerstroke90 has a great reputation on FTE.
Last time that happened to me, with the clunk and all, my axle u joint blew
Old 10-23-2011, 04:15 PM
Special Ed's Avatar
Just come back from Home Depot & also noticed when turning steering wheel vibrates like 4x4 is on but its off. Also shaft coming out transfer case to front diff is turning. Is it suppose to turn in 2WD?
Old 10-23-2011, 04:39 PM
Sounds like a hub may be locked in or the transfer case is still in 4x...Prob a hub..get manual hubs if you want no problems.
Old 10-23-2011, 07:16 PM
Pili's Avatar
Pili Pili is offline
Pili is starting off with a positive reputation.
The OP has an 05. There is no aftermarket hub
Old 10-23-2011, 09:40 PM
Brucemich Brucemich is offline
Brucemich is starting off with a positive reputation.
Top pic is original delivered seal as in my 2005 F350SD 4x4truck. Both mine tore apart like yours,but just a dust seal. Lower pic is replacement seal and is a Dana service bulletin upgrade replacement. Apparently they just did one side, lower pic, with upgraded seal and did not do the other side at all. Should be no oil coming out unless inner diff seals damaged when outer dust seals changed. I am a professional helicopter mechanic and I did both my dust seals about 4 months ago on my 05.
Old 10-25-2011, 03:15 PM
Special Ed's Avatar
**UPDATE** Appreciate the replies first of all. Dealer changed both inner axle seals & both auto hubs. Also found 1 u-joint that was tight replacing it also. No leaking now & 4wd works flawlessly again. Amazing how I needed all that after dust seals & vacuum seals. Sure am thankful I purchased an extended warranty. Thank you all for your input.
  #28
Old 06-01-2014, 06:02 PM
Snuggyworm's Avatar
Snuggyworm Snuggyworm is offline
Snuggyworm is a splendid one to beholdSnuggyworm is a splendid one to beholdSnuggyworm is a splendid one to beholdSnuggyworm is a splendid one to beholdSnuggyworm is a splendid one to beholdSnuggyworm is a splendid one to beholdSnuggyworm is a splendid one to behold
don't mean to revive this, but my truck has the same probe on passenger side. i have the updated dust seals on both sides.
  #29
Old 06-01-2014, 06:03 PM
Snuggyworm's Avatar
it only leaks when i engage 4wd. i don't use 4wd so i guess i'm fine. still, i need to fix this.
  #30
Old 06-01-2014, 07:00 PM
bohiaa bohiaa is offline
bohiaa is starting off with a positive reputation.
Man. that is suck a pain in the ***-prin-bottle!!!
had this on my 2000 once. If I remember right there are two seals. one futher down the shaft inside. It really shouldn't get to the other seal. But if it does. then It's trouble....
and there a tool to knock them in with. If you or " THEM " didn't use the tool then you CANT do the job.... " My understanding "
I would holler for ever until they fix it
2008 F250 4x4 V10 - repack wheel bearings Lambo333 1999 to 2016 Super Duty 4 03-06-2017 09:36 AM
Steering Guru's step inside: 1/2 ton 4x4 Q's... blackjack33 1973 - 1979 F-100 & Larger F-Series Trucks 12 05-12-2016 04:06 PM
Escape stuttering or misfiring on acceleration dborns Escape & Escape Hybrid 12 03-02-2016 06:51 PM
Cutch fork dust boot source 70's f600? Notmeofficer Large Truck 10 08-12-2014 04:00 PM
Turbo Discharge Neopreem Rubber Boot 84F150-4x4 6.0L Power Stroke Diesel 5 11-28-2007 07:30 PM
Tags
2003, 2006, 2007, boot, diesel, dust, f250, f350, ford, replace, seal, seals, sealsdust, vacum, vacuum
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
