Along with the reverse lights, i'm mounting up a set of airbags, from an OBS truck. All i needed to do was to cut down about an 1in of U-bolt, for the airbag "plate" to fit over the factory leaf plate. Came out perfect, now to drill some holes to mount it. Not happy about that either (drill holes in frame), but really need the bags.
I'll take another stab at it, later. I cut it and solder in an extension wire to the lights. Hypothetically speaking, when you mention, "switch control in your trans", can something happen to it, even though i have a manual?
Tim, I didn't catch the "6sp" in your sig. (duhhhh) If I had realized you had a manual, I wouldn't have mentioned the whole thing about the trans' switch. Yours doesn't have that multi-function switch, just a simple on/off switch.
Should be installing new injectors new turbo and custom plenums as well as tunes from cale tomorrow. Will take pictures and post up here when done. Hoping that I can get it all done in a day.
