Couple questions
Couple questions
Starting on a new project. 79' shortbed regular 2wd. Has 300-6 in it now have a 347 to put in. 1st question what do I need to change to put in347 motor mount wise. Number 2 I'm wanting some 1 3/4" headers, what headers are available. Will fox body shorties work. Or does someone make a big tube full length. I've looked but haven't found much.
Mount perches will be different, be carefull with full length headers as the frame cross member below the oil pan will more thn likely be different. I found this out doing a engine swap but I went from big block to small block and found that cross member would not allow for long tube headers so I ended up with shorties.
Jrcrispy2
12-20-2017 12:48 PM
1955effie
01-15-2006 12:23 PM
