brake anchor pin.... how to undo ??? - Ford Truck Enthusiasts Forums
Old 10-12-2011, 10:33 PM
mike bell mike bell is offline
mike bell is starting off with a positive reputation.
Bought chiltons.....mentions it .....but not how to undo......the new ones that came with the new shoes on my 4x4 350 duelly ( 1996 ) look like little little wheel studs with splines....dont want to get out the BFH and ruin things any u tube video or .....mike in omaha
Old 10-12-2011, 11:23 PM
White 97 xlt's Avatar
White 97 xlt White 97 xlt is offline
White 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputation
Is this for the parking brake lever? I'm having trouble picturing what you are talking about..
Old 10-12-2011, 11:44 PM
top of drum brakes ..... post shoes pivit on
the emergancy brake cable is fastened here also
Old 10-13-2011, 12:02 AM
The anchor pin above the wheel cylinder is NOT removable on most applications. There is really no need to remove it unless it is worn out, if that is the case you'll need to replace the whole backing plate..
Old 10-13-2011, 12:22 AM
thank you for the pic.....the cable that attaches up
there is broke....I have the new one but cant disassemble to R and R
Old 10-13-2011, 06:33 AM
Nealcrenshaw's Avatar
Nealcrenshaw Nealcrenshaw is offline
Nealcrenshaw is starting off with a positive reputation.
There should be a nut on the back of the pin.
Old 10-13-2011, 08:19 AM
I will look tonight.....old salter truck....somethings are so disolved they are hard to make out mike in Omaha
Old 10-13-2011, 09:04 AM
bashby's Avatar
bashby bashby is offline
bashby is a name known to allbashby is a name known to allbashby is a name known to allbashby is a name known to allbashby is a name known to allbashby is a name known to all
Quote:
7/16 sockety fits, IIRC
Old 10-13-2011, 02:18 PM
tbirdscott's Avatar
tbirdscott tbirdscott is offline
tbirdscott is starting off with a positive reputation.
Just did brakes two days ago, bashby is correct with the 7/16" socket. I also needed a set of vise grips to hold the stud from spinning.
Scott
Old 10-13-2011, 03:38 PM
andym's Avatar
andym andym is online now
andym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputation
If it or the backing plate is rotted bad enough, you'll have to replace the whole backing plate. I could grab a set of rust-free ones off a CA truck next time I'm at the junkyard if you need them.
Old 10-13-2011, 09:20 PM
THANKS GUYS THIS WEEKEND MIKE
66 f100 shift tube removal Jared96f150 1961 - 1966 F-100 & Larger F-Series Trucks 19 07-16-2016 06:40 PM
Stripped transfer case drain plug Mikeyg76 2009 - 2014 F150 4 06-03-2016 01:09 AM
undoing a 4x4 swap momutt 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 20 12-19-2015 02:41 PM
How to undo what was done Hard at work 1999 to 2016 Super Duty 10 01-25-2015 08:09 AM
Fuel filter removal 5.4 TYZ78F150 Excursion - King of SUVs 7 03-22-2010 03:34 PM
Tags
1993, 1995, 96, anchor, backing, brake, brakes, drum, f350, ford, pin, plate, ranger, rear, replace, top
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
