Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428)
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 10-12-2011, 09:25 PM
bigfoot22's Avatar
bigfoot22 bigfoot22 is offline
1974 Ford F-100
bigfoot22 is starting off with a positive reputation.
360/390 Question
Will a 1965 390 intake work on a 1974 360 engine?I've been wanting to go with a intake and a 4 bbl. carb. to replace the stock 2 bbl. intake and carb.not much knowledge in this department.
If I find one(intake) which carb. should I go with?Holley 4160,4150.
Summit has one that looks real sweet for a little over 200 bucks also.
don't know much about that either..
Thanks for the help.
__________________
I have a '74 FORD pickup
I want a '56 ford 2 dr mainline
  #2 (permalink)
Old 10-12-2011, 10:40 PM
DeepRoots DeepRoots is offline
Garage is empty, add now
DeepRoots is gaining momentum as a positive member of FTE.
intakes should swap out no problem. Might be different port sizes.
I like 4150 carbs better than 4160's due to my own experiences.... I just don't like the balance tube and metering plate.
I've got an 1850-2 carb if you want to drop me a line. it's just sitting on the shelf taking up space.
__________________
-76 F100 390FE
-63.5 Galaxie 500 -429cj
Tags
1974, 360, ford, va
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
