stupid rotted brake lines
#31
I have been asking that for years. With all the recalls and lawsuits because of safety you would think something so prone in the brake system would be mandatory stainless.
#32
#33
#34
#35
The nickel copper alloy is standard on many European models, and is very easy to bend and flare.
#36
#37
Put me on that list. I've driven for almost 50 years, mostly in Florida, and have never flushed the brake fluid on a vehicle. Almost 500,000 mile on the 3 Fords that I have now and pads, shoes, and rotors is all I've done to the brakes. Same for all my previous Fords.
#38
I wish we could get 10 years out of a brake line!
If I were to do replacement of steel brakes lines as a preventive maintenance dead here I would have to do it every single year! I have new steel brake lines rot out within 2 years!
I have installing nicopp line in all our trucks now when first putting them on the road. Haven't had to replace a line yet on any of these!
Attachment 289194
Attachment 289194
#39
Quote:
Originally Posted by superdave02f552 View Post
the 8' near the filter you speak of where is that? there is not any 3/16 for the rear run until it hits the tee on the axle
You are correct, the 1/4 was from the rear tee forward, the 3/16 was from the tee to the rear calipers.
And what about the fittings, what do I search for to find those?
#40
i used one 25' roll of 1/4" for the rear and one half roll of 3/16 to do the front portions that i didnt buy from ford. up by the abs unit i reused the original fittings and where i could i got them from the parts store
#41
#43
Yes, very easy to bend and work with as it is nearly half copper. I used no tools to bend up the lines for the last 3 work trucks we have. But when I bend up lines for nice cars I use tools so the bends are uniform and nice.
It also flares easily, cleanly, and seals very well when the fitting is tightened. I have found you don't need to tighten the fittings down nearly as much as steel line to get the joints to seal.
flat48f2
02-19-2016 12:22 PM
jonesg
08-05-2014 07:55 PM
nordvik72
19
07-25-2009 11:25 AM
