1956 F100 Crew Cab Project Started - LOTS OF PICTURES - Page 18 - Ford Truck Enthusiasts Forums
  #256
Old 06-10-2014, 08:52 PM
dynamic's Avatar
dynamic dynamic is offline
dynamic is a splendid one to beholddynamic is a splendid one to beholddynamic is a splendid one to beholddynamic is a splendid one to beholddynamic is a splendid one to beholddynamic is a splendid one to beholddynamic is a splendid one to behold
Next....
I moved on to installing my new Power Cowl Vent from Millstone Automotive.
The ad states....
1956 Ford Power Cowl Air Vent Kit
This is a complete kit that motorizes the cowl air vent on 1956' Ford classic trucks, by eliminating the manual handle and linkage and replacing it with a 12-volt actuator.
Perfect for use with center mount a/c units. Easy to install, Direct Bolt-On, Pre-wired and water proof.
lets just say... nothing is perfect...
first... this thing didn't "direct bolt-on"
The lower hole was off a solid 3/16-1/4".
Then once you get it all mounted and test it out....
the cowl only opens 3/4 at best and it doesn't close tight. It will require some re-engineering on my part.
Now I know what your saying... maybe my truck has been messed with. Nope... all original brackets, correct 1956 arm, and handle as well as stock hardware...
ohh... and as I already knew this thing is as slow as fresh maple syrup. Maybe the fact that the motor says it is a 24v setup has something to do with it slow speed.
anyway... here is a first install picture.
  #257
Old 06-10-2014, 08:57 PM
dynamic's Avatar
And to finish out my productive weekend...
I started installing (test fitting) my HVAC setup from Vintage Air.
after rummaging threw my plumbing draw at home I remembered I had some flexible plumbing strap from my previous job as a duct board installer.
adjusting the box was simple using the strapping and I feel comfortable with its location.
Now I just need to fab up the brackets and start cutting more holes in the fire wall for the lines to exit thru.
  #258
Old 06-10-2014, 11:20 PM
bjmayberry2's Avatar
bjmayberry2 bjmayberry2 is online now
bjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud of
Great progress! Really enjoy your thread.
  #259
Old 06-26-2014, 06:39 PM
ChaseTruck754's Avatar
ChaseTruck754 ChaseTruck754 is offline
ChaseTruck754 has a great reputation on FTE.ChaseTruck754 has a great reputation on FTE.ChaseTruck754 has a great reputation on FTE.ChaseTruck754 has a great reputation on FTE.ChaseTruck754 has a great reputation on FTE.
Like the progress!
What AC setup is that? I know you said Vintage Air, but is it their generic one or what? Does it have a heater core & fan in it too, or is it just the AC?
I need to figure out something for my '74 crew pretty soon so looking at options.
  #260
Old 06-26-2014, 08:09 PM
dynamic's Avatar
http://m.summitracing.com/parts/vta-61005-vuz-a?seid=srese1&gclid=CO76tcvhmL8CFUiGfgod91kAFA
Super gen II heat/ac/defrost
  #261
Old 06-27-2014, 01:38 PM
Thanks for the info. Interested to see what you do for setup & controls etc. on this
  #262
Old 06-27-2014, 04:47 PM
dynamic's Avatar
Quote:
Stay tuned.
It will be a while before I get to controls and duct plumbing.
  #263
Old 06-27-2014, 04:51 PM
no problem! I've been "ready" to do this AC for my crew for about 2 years now. My "1 year" crew project is now in it's 5th year with little to no work done in the last year or more. I have a 4 month old daughter now so the progress has REALLY gotten slow...
I think you'll get to it before I do!
  #264
Old 06-27-2014, 05:14 PM
dynamic's Avatar
Factory setup would work for u too.
  #265
Old 06-27-2014, 05:35 PM
what factory setup? If you mean the whole AC box, that big, stupid thing they put in the engine compartment on the 70's stuff, then no, it won't. Got the exhaust pipe coming out of the turbo sitting right there
  #266
Old 06-27-2014, 06:32 PM
dynamic's Avatar
Ahhhhh. Then a vintage air kit is for u.
  #267
Old 06-27-2014, 06:35 PM
Quote:
yeah. Looked at "dealer" air (under the dash) stuff and then went toward NAP (Nostolgia Air products) kit for the 73-79 that is a heater & AC in one, but seen a negative review or 2 on here for it recently so a little uncertain at this point.
  #268
Old 06-27-2014, 07:17 PM
dynamic's Avatar
I know they make kits that allow u to use the factory cable controls in older cars. I would contact them when u are ready, they should be able to help u out.
  #269
Old 06-27-2014, 07:19 PM
good to know - thanks!
  #270
Old 06-28-2014, 11:05 PM
dynamic's Avatar
Here is a picture of the crown vic booster vs the old corvette style booster that came with the pedal box.
you can see why switching to the crown vic unit will equal better vacuum for stopping.
After gathering a few pedal boxes for parts and putting much thought into my clutch pedal modification, I started mocking things up....
The kit gives you a long bolt with a tube which the brake pedal and booster push bracket is attached to.
I needed to come up with a way to add a clutch pedal to this setup.
So....I ended up buying a double threaded stud from Grainger to use as my pedal pivot assy. 1/2-13 x 10" long.
And then cut off all the extra tube from the soon to be clutch side of the pedal setup.
I reinstalled the plastic busing in the cut off tube.
Then I took apart the pedal box I grabbed from a 1996 f250 pickup for the clutch pedal. I removed the spring bar that was welded to the pedal.
And then grabbed the mustang clutch pedal kit and stripped out the rod for the quadrant parts.
And started bolting things together to see if things will fit.
There is no clearance to use the stock plastic adjusting quadrant (not that I intended on doing so) so I will be using a firewall adjuster and a metal/aluminum quadrant.
I need to pull the pedal box out of the truck and weld all the nuts in their places and lock down the clutch pedal so it will rotate the quadrant.
I will also be adding a brace between the brake pedal and the clutch pedal to add some strength to the setup, after all it is a mustang/crown vic drive train....
Im sure I will never spin the tires or drop the cutch....
1956 COE followed me home jmadsen 1948 - 1956 F1, F100 & Larger F-Series Trucks 11 01-16-2017 01:00 PM
1956 FORD COE C600 BUILD dynamic 1948 - 1956 F1, F100 & Larger F-Series Trucks 143 11-09-2016 07:22 PM
Plow mount brush guard install dynamic 1999 to 2016 Super Duty 2 09-25-2016 09:13 PM
Third brake light options??? dynamic 1948 - 1956 F1, F100 & Larger F-Series Trucks 10 12-22-2015 06:51 PM
DOOR HINGE IDENTIFICATION dynamic 1957 - 1960 F100 & Larger F-Series Trucks 10 06-21-2012 06:33 PM
Tags
1956, 56, buddy, cab, cabs, crew, double, f100, fioo, fire, maryland, md, pictures, sale, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
