LMC has Radiator Supports for 1965 F100 - Page 2 - Ford Truck Enthusiasts Forums
Old 10-14-2011, 03:51 AM
camperspecial65 camperspecial65 is offline
camperspecial65 has a good reputation on FTE.camperspecial65 has a good reputation on FTE.camperspecial65 has a good reputation on FTE.
The radiator mounting and battery trays are different from 65 to 66 as well as 61-4 also...
61-4 2WD trucks battery is mounted on the firewall next to RH hood hinge.
65 is the tray with 2 triangular brackets which mount to the core support..two of the inboard bolts goes through the radiator mounting bracket on the core support. The outboard bracket has 2 bolts which bolt to the main core support There is also a bolt/nut that goes through the fender apron anchoring the actual tray to it as well.
66 is the same as 65 except there are no bolts/nuts that goes through the radiator mounting ear...no ears to go through...instead the inboard tray bracket has 3 bolts as I recall which bolt to the core support in the same fashion as the outboard bracket on the 65 tray. Theres also the bolt/nut that goes through the tray and fender apron as in the 65 trays.
- cs65
Old 10-16-2011, 07:57 PM
kelwar kelwar is offline
kelwar is starting off with a positive reputation.
Basically all you need to do to use a 65 support in a 66 is flip the brackets around that are soldered to the rad (basically turns the rad into a 65 rad)
Old 10-17-2011, 01:36 AM
And you will need a 65 battery tray too as theres no nutplates on the inboard side to accomodate the 66 tray as the 65 inboard bolts to the radiator mounting flange that got deleted in 1966. Theres also 2 stiffener brkts used on 65 for the radiator mounting ears/brackets which also were deleted in 1966 too.
- cs65
Old 11-25-2013, 04:31 PM
Jon003 Jon003 is offline
Jon003 is starting off with a positive reputation.
Quote:
Originally Posted by jmf66 View Post
I wonder what the difference is between the newly offered 65 support and the 61-64 that's been re-poped for a while now. I'm thinking the 65 still has the round inner fender mounts and the same radiator mount as the 61-64, so what's the difference?
I bought a 61-64 support last year and modified it for my 66 2wd. It took a few hours to transfer the inner fender mounts, remove the radiator mounts, and to drill new holes to mount my radiator and battery box. Interesting that they now offer a 65 2wd support, but not the 66 yet.
Jerry, I am getting ready to do the same thing you did for my 65 2W F250. I am removing a core support from a 61-64 2wd and want to know what I need to modify forsure. I have the same inner fenders on my 65 as a 66 has. I see what you have listed but do you have any pictures of what you did? This made sense for me because the support I found was in very good shape and the guy sold it to me for 30 bucks.
Old 11-25-2013, 04:39 PM
jmf66's Avatar
jmf66 jmf66 is offline
jmf66 is starting off with a positive reputation.
You'll have to modify as I mentioned above. I don't have any pictures, but I did find this article with pictures that describes exactly what I did.
1966 Ford F100 Restoration: Using the reproduction core support
When you get your old core support out and compare it side-by-side with the 61-64 support, it'll make better sense on what you'll need to do.
Old 11-25-2013, 04:46 PM
Jerry, thanks. This is just what I was looking for.
Styleside Tailgate Needed 1960 F100 montego69 WTB - Parts & other 2 08-02-2016 03:01 PM
C5TZ-10732-C .. Battery Tray 1965/1966 4WD Atlasts Ford Truck Parts for Sale 1 05-29-2016 11:42 PM
Repro Radiator Support Quality matt2491 1961 - 1966 F-100 & Larger F-Series Trucks 2 01-03-2016 05:23 AM
Radiator support question The Masked Rider 1961 - 1966 F-100 & Larger F-Series Trucks 1 11-19-2014 12:21 PM
Ordering King Pins and Cab mounts... desertwest 1961 - 1966 F-100 & Larger F-Series Trucks 3 12-30-2013 10:39 AM
Tags
1965, 1966, 65, 66, battery, core, f100, fender, fit, ford, lmc, mounts, radiator, support, tray, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
