New Idea for Under-Intake Carb Heat
Ahhh... Blue flame 235. I had one in my '57 Chevy 150. Nice engine.
I wonder if the exhaust that comes out of the EGR port on the back of the manifold would have cooled down enough? I know the exhaust that comes out directly is WAY too hot, which is why the stock setup has the heat riser on it to shut it off above a certain temperature. If it was constantly hot, wouldn't it just cook the underside and overheat the fuel?
I know that this is an insane thought an all...but what about glow plugs? They preheat diesels....And they shut off after a certain amount of time.....
Might be something to look into AB....Of course, I'd assume one would have to drill and tap into the intake, and then fit 6 GP's, etc have all the wiring, etc.....Just a thought....Now expand on it...lol
Hi newbie here, I'm just starting to pull together pieces for my offy/split manifold project and have been thinking about the same issue, and had a thought, has anyone ever had a heated seat apart? Just wondering what kind of elements are built into heated seats, so there you have a 12 volt heat source.....
Resurrecting an old thread with a new link
Adding a link to this thread for the pad heaters (the padheaters site is down):
80 watt/12V/6.7Amp
Item#09 Model#80/12 - Proheat Heavy Duty Fluid Reservoir Heater ProHeat products INC. the originator and inventor of fluid reservoir, motor engine flexible pad heaters [80/12] - $35.95 : Proheat Products Inc., engine heater, engine heater systems, fl
and:
150 watt/12V/12Amp
Item#10 Model#150/12 - Proheat Heavy Duty Fluid Reservoir Heater ProHeat products INC. the originator and inventor of fluid reservoir, motor engine flexible pad heaters [150/12] - $39.95 : Proheat Products Inc., engine heater, engine heater systems,
80 watt/12V/6.7Amp
and:
150 watt/12V/12Amp
I believe I actually contacted them about those pad heaters back when I was originally looking at the idea. They said it wouldn't work very well as it doesn't heat up very quickly (claims it can warm up oil from below freezing in just under 2 hours) , and don't get all that hot.
We need around 200° or so, and those only get up to around 50°-ish. Just enough to keep the oil warm and thin.
You've prob mentioned this and i didn't see it, but : While browsing I came across a kit that Clifford used to sell for the purpose of heating their intakes. It was a plate, like used for coolant, but they supplied fittings and copper tube that the owner was supposed to drill into their headers or pipes, and soldier on, thereby supplying exhaust heat, fast and furious to the underside of the intake. I've since seen one or two Cliff's around with the tubes attached.
Of course the new Clifford's have a provision for coolant.
1981 ford 1/2 ton 4x4 6cyl.
It runs good, but is running a little rich currently...Not a bad buy actually
Do you have a link to this setup?
Originally Posted by JohnSmith3524
There is an install like this on the local craig'slist.
#29
This is a old thread but someone might be able to use the info on carb and manifold heat found here
FORDSIX PERFORMANCE • View topic - PICK your POISON, manifold oppinion post!
68cabby
01-09-2013 09:30 PM
68cabby
24
01-08-2013 09:25 PM
