New Idea for Under-Intake Carb Heat
Old 10-13-2011, 07:08 PM
AbandonedBronco's Avatar
AbandonedBronco
AbandonedBronco is offline
Ahhh... Blue flame 235. I had one in my '57 Chevy 150. Nice engine.
I wonder if the exhaust that comes out of the EGR port on the back of the manifold would have cooled down enough? I know the exhaust that comes out directly is WAY too hot, which is why the stock setup has the heat riser on it to shut it off above a certain temperature. If it was constantly hot, wouldn't it just cook the underside and overheat the fuel?
Old 10-14-2011, 01:47 AM
SideWinder4.9l's Avatar
SideWinder4.9l
SideWinder4.9l is offline
I know that this is an insane thought an all...but what about glow plugs? They preheat diesels....And they shut off after a certain amount of time.....
Might be something to look into AB....Of course, I'd assume one would have to drill and tap into the intake, and then fit 6 GP's, etc have all the wiring, etc.....Just a thought....Now expand on it...lol
Old 01-28-2012, 07:17 PM
Wgilliam's Avatar
Wgilliam
Wgilliam is offline
Hi newbie here, I'm just starting to pull together pieces for my offy/split manifold project and have been thinking about the same issue, and had a thought, has anyone ever had a heated seat apart? Just wondering what kind of elements are built into heated seats, so there you have a 12 volt heat source.....
Old 01-28-2012, 07:23 PM
AbandonedBronco
Wow, I'd hadn't even thought of that. If they're a coiled wire, it might be something you could just wrap around the intake itself. Might have to look into that.
Old 01-29-2012, 08:33 PM
SideWinder4.9l
It's a type of ceramic plate....Not a simple coiled wire...
Old 06-25-2014, 10:35 AM
Akhnot's Avatar
Akhnot
Akhnot is offline
Old 06-25-2014, 10:52 AM
AbandonedBronco
I believe I actually contacted them about those pad heaters back when I was originally looking at the idea. They said it wouldn't work very well as it doesn't heat up very quickly (claims it can warm up oil from below freezing in just under 2 hours) , and don't get all that hot.
We need around 200° or so, and those only get up to around 50°-ish. Just enough to keep the oil warm and thin.
Old 06-25-2014, 01:16 PM
F-250 restorer's Avatar
F-250 restorer
F-250 restorer is offline
You've prob mentioned this and i didn't see it, but : While browsing I came across a kit that Clifford used to sell for the purpose of heating their intakes. It was a plate, like used for coolant, but they supplied fittings and copper tube that the owner was supposed to drill into their headers or pipes, and soldier on, thereby supplying exhaust heat, fast and furious to the underside of the intake. I've since seen one or two Cliff's around with the tubes attached.
Of course the new Clifford's have a provision for coolant.
Old 06-25-2014, 03:44 PM
6978sghfbjklgdfsjhkl's Avatar
6978sghfbjklgdfsjhkl is offline
There is an install like this on the local craig'slist.
1981 ford 1/2 ton 4x4 6cyl.
It runs good, but is running a little rich currently...Not a bad buy actually
Old 06-25-2014, 05:40 PM
AbandonedBronco
Something like that would be nice. I actually tried to look up something like that originally, but couldn't find anything that was dry. Most everything was for some tank that heated the liquid around it. In return, the liquid kept the heat dispersed and kept it from burning up. Thought about wrapping the intake in coiled copper wire, but then came upon the issue of temperature control. How to cut the current once it reached a certain temp, etc.
Do you have a link to this setup?
That's not a bad buy at all. The cost of the carb, intake, and headers new is over that price.
Old 06-25-2014, 06:37 PM
BaronVonAutomatc's Avatar
BaronVonAutomatc
BaronVonAutomatc is offline
I'd like to see someone with mad fab skills throw together an exhaust heated box that includes a functioning EGR valve for the Offy intakes.
Old 06-27-2014, 11:12 AM
tinman52's Avatar
tinman52
tinman52 is offline
Welder User
Anybody know what the temperature of the manifold should be for optimal atomization? Having it too hot is probably not a good idea either. According to the web, gas boils from 100-400 degrees F depending on a bunch of variables.
Would be nice to have a way to control the carb heat.
  #28
Old 07-04-2014, 11:31 AM
F-250 restorer
Here is a photo of a system similiar to what Cliffords used to sell. This is of a Chevy intake, so I hope the photo won't burst into flames here. The actual Cliff. system has two copper tubes welded into the headers. Cheers.
  #29
Old 07-24-2014, 03:02 AM
hermancm's Avatar
hermancm
hermancm is offline
This is a old thread but someone might be able to use the info on carb and manifold heat found here
FORDSIX PERFORMANCE • View topic - PICK your POISON, manifold oppinion post!
68cabby
01-09-2013 09:30 PM
68cabby
24
01-08-2013 09:25 PM
coolguy1419
11-02-2010 08:07 AM
hgb4x4
10-31-2010 06:47 PM
ROCKYTULSA
05-30-2010 10:26 PM
Quick Reply: New Idea for Under-Intake Carb Heat
