Torque converter upgrade review
just wondering if anybody out there can help me with a torque converter question.
Im looking to upgrade and was wondering if anyone can point me in the right direction for a good converter. Im looking to get one that can withstand lots of torque!!!! all responses will be greatly appriciated
What you are doing withnthe truck is mostly what will dictate the converter you will need, the best advice I can give you is to look into a complete bulletproofed trans w/ t/c from John Woods or Brians Truck Shop ^so you won't have to worry bought how much torque or HP you ever put into it...and that's no joke. They both guarantee their transmissions period, end of story.
Jim & fat Monty
Jim & fat Monty
on
I modded the pump myself using parts included in my TransGo reprogramming kit. I also replaced the boost valve for the pressure regulator and the lock up valve for the TC. The 4R100-LU valve converted the TC lock up from pulse width modulated to 0n-Off operation. The first time I went into the trans was a matter of necessity and I didn't have much time to research things beforehand. I learned alot about more upgrades/mods later and did them the next time around.
Oh and on the subject on hand I have been looking at torque converters too. And they cost and arm and leg. And I had seen that if you blow the trans and you want that new torque converter cleaned out and rewelded you are looking at $400-$600 on top of the cost of TC. So that is an other reason NOT to replace TC until it is rebuild time.
on
. But my question for you is after doing these mods is it going to help or hurt my stock torque converter? That and how did you line up the pump half's when putting the pump together? I was going to buy alignment dowels for the 4r100.
I used metric bolts of the proper size with piece of plastic tubing around them as my alignment dowels for the pump bolt holes. I placed some thin strap around the outside perimeter and tightened it down with a couple of large worm gear hose clamps.
Personally, unless you are 100% sure the trans isn't going to take a dump any time soon, I'd wait on replacing the TC until a rebuild.
Are you replacing the stator shaft TC seal ring and the Coast Clutch seal rings on the pump also? You just want to be sure you have everything before you do this project.
As long as your trans is functioning normally, I see these mods as a way of extending its life.
on
Thanks for pointing out the stator shaft TC seal ring and the Coast Clutch seal I am hoping that comes with my master overhaul gasket set. Was there any special tricks to replacing the front and rear pump bushings ? And what kind of TC did you use ? And I am going to wait to replace my TC until I do a complete overhaul. And I am hoping these mods will extending its life until I have the cash to put all the little goodies in the trans and valve body or just get a BTS trans.
Make sure you install the bushing's lube groove in the same position as the old one. IIRC, One of the bushings was staked in place and I staked the new one also. I used a TC from Midwest Converters. It was part of a kit that was included as a upgrade for my first rebuild. It is a billet 3 disc clutch TC. I got a discount for purchasing several components together and it ended up being IIRC ~ $800.
Jasonnoel
09-16-2014 01:57 PM
2FordTrucks
05-08-2003 12:05 AM
