rear anti lock brake light on
hey guys, my rear anti lock light keeps flashing on and off and as of just recently it just stays on the whole time. but the truck still seems to brake just fine. could the problem be from a bad sensor? and if so, where is the sensor located at? oh and the truck is a 5.0 AOD trans. 2 wheel drive
thanks
thanks
Assuming you have a 92-96, I just learned this week that the Hydraulic rabs valve is on the left frame rail just downstream of the master cylinder. Has a 8" long wire pigtail coming out of it. The electronic module is behind the glove box. Approx 4"x6" block box. The sensor is mounted on top of rear diff and it is the vehicle speed sensor, so if speedo works good, probably not the culprit. These are the locations of the parts on my 96 F250.
DBANDGB
08-29-2017 05:39 PM
rusted&busted
07-27-2008 09:30 PM
DJdemon6696
08-02-2007 03:45 PM
