rear anti lock brake light on - Ford Truck Enthusiasts Forums
Old 10-12-2011, 01:22 PM
Nally427 Nally427 is offline
Nally427 is starting off with a positive reputation.
hey guys, my rear anti lock light keeps flashing on and off and as of just recently it just stays on the whole time. but the truck still seems to brake just fine. could the problem be from a bad sensor? and if so, where is the sensor located at? oh and the truck is a 5.0 AOD trans. 2 wheel drive
thanks
Old 10-12-2011, 01:34 PM
jimbo285's Avatar
jimbo285 jimbo285 is online now
jimbo285 is starting off with a positive reputation.
Assuming you have a 92-96, I just learned this week that the Hydraulic rabs valve is on the left frame rail just downstream of the master cylinder. Has a 8" long wire pigtail coming out of it. The electronic module is behind the glove box. Approx 4"x6" block box. The sensor is mounted on top of rear diff and it is the vehicle speed sensor, so if speedo works good, probably not the culprit. These are the locations of the parts on my 96 F250.
Old 10-12-2011, 01:38 PM
yea i dont know if that would be the same as what i have. sorry i forgot to mention its a 89'. but it wouldnt hurt to go look to see if the setups are the same
1991 F350 4X4 Anti Lock Brakes 1972RedNeck Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 4 03-13-2016 08:42 AM
rear anitlock brake light justinlb917 Ranger & B-Series 1 12-12-2013 09:49 AM
'91 F350 Gasser Anti-lock brake light bigredcrewcab 1987 - 1996 F150 & Larger F-Series Trucks 4 03-11-2013 10:11 PM
Anti-Lock Brake Problem Blujay96 1999 - 2003 7.3L Power Stroke Diesel 0 12-10-2010 05:58 AM
Rear Anti-lock Brake light??? jmmartin Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 3 03-23-2010 02:33 PM
Tags
150, 1987, anti, antilock, brake, brakes, bronco, f150, f250, ford, ii, light, lock, rear, stays
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
