transmission problem - no reverse - Ford Truck Enthusiasts Forums
Old 10-12-2011, 09:27 AM
gravel pit camper gravel pit camper is offline
gravel pit camper is starting off with a positive reputation.
i got a 2004 F150 that won't go into reverse. All other gears work, including 4 wheel drive. I checked the linkage and it is working. Any suggestions? thanks
Old 10-12-2011, 10:32 AM
jk080's Avatar
jk080 jk080 is offline
Gear Head
jk080 has a very good reputation on FTE.jk080 has a very good reputation on FTE.jk080 has a very good reputation on FTE.jk080 has a very good reputation on FTE.
The number one reason for no reverse with that trans is a broken sun gear shell, but when this happens you will also have no 2nd and 4th. You said all the other gears work fine, do you mean that you can shift into them with the shifter or you have all the forward gears when you drive the vehicle?
Other reasons for just no reverse can be a failed reverse servo or its snap ring or a broken reverse band.
No Reverse lights WildMav 1987 - 1996 F150 & Larger F-Series Trucks 3 01-10-2017 01:48 PM
95 f250 reverse gear problems Sam's The Man 1987 - 1996 F150 & Larger F-Series Trucks 5 03-06-2016 07:28 AM
1987 F350 Reverse lights troupstree 1987 - 1996 F150 & Larger F-Series Trucks 12 07-07-2014 11:17 AM
Reverse lights wreckinball Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 6 06-01-2010 02:32 PM
No Reverse AOD !!!! otto Clutch, Transmission, Differential, Axle & Transfer Case 2 01-24-2001 10:58 AM
Tags
2003, 2004, 2007, 200r, band, broken, f150, ford, problems, reverse, shell, sun, transmission, truck, trucks, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
