Pre bent brake lines? - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Old 10-12-2011, 07:26 AM
62uni4x4's Avatar
62uni4x4 62uni4x4 is offline
62uni4x4 is starting off with a positive reputation.
well... My truck has been quite the A**hole lately. first it was the vacuum pump. Then three days after that the alternator decided it didnt like the batteries any more. got that fixed. then last night i step out on the front porch to have a smoke and notice my exhaust hanging, No big deal right? I wanted to do exhaust anyway cause the P.O. did a serious hack job under there. So I pulled remaining pieces off so it didnt hurt anything while i collected parts. and heres the kicker! I jump in the thing this morning to come to work... fire it up... push the brake to put it in reverse and it goes right to the floor!!! hop under the truck and sure enough the brake line is rotted out right at the hose in the rear. so on to may question. sorry for the rant.
do you guys know where I can buy pre bent good quality OEM like brake line? or even good quality material to make my own? I have a lot of experience with the auto supermarket flavor brake line and here in michigan with the salt they only last a couple years. Maybe a Stainless one?
Thanks in advance all...
Old 10-12-2011, 07:53 AM
Neal 97 250's Avatar
Neal 97 250 Neal 97 250 is offline
Neal 97 250 has much to be proud ofNeal 97 250 has much to be proud ofNeal 97 250 has much to be proud ofNeal 97 250 has much to be proud ofNeal 97 250 has much to be proud ofNeal 97 250 has much to be proud ofNeal 97 250 has much to be proud ofNeal 97 250 has much to be proud ofNeal 97 250 has much to be proud of
I was going to suggest get one at auto zone and bend it but it sounds like you have been thru that already.
My only guess would be the stealership. or full custom stainless. Maybe a hydraulic shop has something to help you out.
Old 10-12-2011, 07:56 AM
62uni4x4's Avatar
Steelership says no way too old... looks like maybe LMC truck. they have them for F250?? should be about the same right? however I have to buy the whole kit front and rear...
Old 10-12-2011, 08:21 AM
BIGRED 7.3L's Avatar
BIGRED 7.3L BIGRED 7.3L is offline
BIGRED 7.3L is gaining momentum as a positive member of FTE.
This is were I got my stainless. They were very exact and worked well. Worth not bending my own. I got my hoses off Rock Auto. I have an extra rear hose if you are intrested.
Inline tube - Online Catalog - Ford
Old 10-12-2011, 09:40 AM
craftsmangary's Avatar
craftsmangary craftsmangary is offline
craftsmangary is starting off with a positive reputation.
I have always bent my own lines from bulk tubing but this time a bought a stainless set from Inline tube I also bought a set of stainless trans cooler lines, I will be putting them on in the next few days. I wish Ford would build them with stainless lines from the start.
Old 10-12-2011, 02:07 PM
62uni4x4's Avatar
Thanks guys.
I dont see an offering for the regular cab though. I guess I could shorten them...??
Old 10-12-2011, 02:12 PM
Quote:
Originally Posted by 62uni4x4 View Post
Thanks guys.
I would call them. they can do it I am sure. I also just got an email on Rock Auto close out specials that include brake hoses for the rear for less than $9
Old 10-12-2011, 03:55 PM
I bought the CC set and I plan to shorten the rear line.
Old 10-13-2011, 07:06 AM
62uni4x4's Avatar
Quote:
thats my plan. stuff is on its way. Thanks again for the info. It would be great if they put stainless brake lines on from the factory as mentioned above.
Can't get this line in. Right front brake line. Salty Dog 1967 - 1972 F-100 & Larger F-Series Trucks 13 01-28-2016 10:36 AM
pre-bent brake lines? cjben 1987 - 1996 F150 & Larger F-Series Trucks 7 08-25-2015 05:56 PM
pre bent Crewcab fuel and brake lines?? HpCowboy13 1973 - 1979 F-100 & Larger F-Series Trucks 7 02-16-2015 09:24 PM
Pre Bent Brake lines tfs2403 Excursion - King of SUVs 0 04-26-2014 11:02 AM
Pre Bent SS brake lines BigBlack71 1967 - 1972 F-100 & Larger F-Series Trucks 6 12-03-2010 09:13 PM
Tags
1996, 250, bent, brake, brakeline, f250, f350, ford, line, lines, oem, pa260, pre, prebent, replacement
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
