How to change u-joints at front hubs - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 10-11-2011, 10:21 PM
fmx_freak's Avatar
fmx_freak fmx_freak is offline
fmx_freak is starting off with a positive reputation.
I did some searching but couldn't find a thread regarding a how-to for changing the u-joints on the front axle at the hubs, so I apologize if it's out there and I'm double posting...
I have a 99 F-250 crew cab SD 4x4 and the u-joints on the front axle at the hubs have absolutely no needle bearings left - completely gone. I've done the ball joints and wheel bearings in the past, but would just like a refresher on the steps to get at the u-joints that connect to the front hubs to replace them.
Thanks in advance!
Old 10-11-2011, 11:00 PM
fmx_freak's Avatar
Thumbs up Found it!
Old 10-12-2011, 12:28 AM
A/Ox4's Avatar
A/Ox4 A/Ox4 is offline
9 ECHO 1
A/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputation
Old 10-12-2011, 01:18 PM
BCHauler's Avatar
BCHauler BCHauler is offline
BCHauler has a good reputation on FTE.BCHauler has a good reputation on FTE.
That is in awesome video link. Thanks a lot!
Old 10-12-2011, 01:24 PM
A/Ox4's Avatar
9 ECHO 1
Glad to help
Old 10-15-2011, 04:46 PM
akbertha akbertha is offline
akbertha is starting off with a positive reputation.
nice video, good tips, and many thanks. i'm off to do mine now.
Old 10-17-2011, 12:11 PM
89LX306 89LX306 is offline
89LX306 has a great reputation on FTE.89LX306 has a great reputation on FTE.89LX306 has a great reputation on FTE.89LX306 has a great reputation on FTE.89LX306 has a great reputation on FTE.
Make sure you support the axle ears when you are pressing the u-joints out. I didn't and ended up bending the ears on the long axle shaft. $150 bought me a used shaft. A new one cost $500. I learned my lesson and make sure and share it with others now.
Old 10-17-2011, 11:42 PM
ZBIGBIG19TH ZBIGBIG19TH is offline
ZBIGBIG19TH is gaining momentum as a positive member of FTE.
Looking at your video I decided to do my u-joints ,but i can't get my axle of the knuckle.
Used hammer, pry bar from behind,pull on it ,wiggled and nothing .
It stretches the seal but it will not come off. I did the install 4 years ago and did put some grease on the outside of the seal so it should not be seised.
What to do?I think I'll just order new seal and cut old one.
Any tricks to get it off?
thanks
Old 10-18-2011, 08:16 AM
Bigpipes 35's Avatar
Bigpipes 35 Bigpipes 35 is offline
Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.
When I did mine I basicaly had to destroy the seal to get it off , Just beat the heck out of it from the back , It will go
Old 10-24-2011, 10:24 AM
Ok done but it was a bit@@ to get them of. One seal changed,one still like new so i kept it on.
One U-joint was all rusted inside and stiff like hell. Got ones with zerks so I should be good for long time. Also new back plates(dust shields)installed,old ones rusted out.
After all no more wandering and jerking steering wheel.
Thanks for tips.
Zbig
Changed wheel bearing, still hear noise Grease & Gravel Ranger & B-Series 1 01-24-2016 05:05 PM
Front Locking Hub mich800 6.4L Power Stroke Diesel 15 08-22-2014 08:45 AM
2008 f-350 front axle u-joints 6.4lfirefighter 1999 to 2016 Super Duty 1 07-17-2011 01:53 PM
Front Axle U-Joint Replacement Question robinsonpowerstroke 1999 - 2003 7.3L Power Stroke Diesel 7 08-03-2010 08:33 PM
u-joints in ttb axle fordguy351w Clutch, Transmission, Differential, Axle & Transfer Case 2 12-28-2003 05:54 PM
Tags
08, 1996, 2001, axle, ball, bronco, change, changing, duty, f250, ford, front, install, joint, joints, super
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
