Fx4 Decals
Fx4 Decals
OK so I am considering removing my current Fx4 Decals to install the one of the two in the links below. What I wanted to know is has someone done this and did the current decals come off cleanly without a ton of work?
2010 Ford F150 FX4 Off Road Decals Truck Stickers - F | eBay
97 - 08 Ford F150 FX4 Off Road Decals Truck Stickers FB | eBay
I really like the 2010 or newer decals but I am just not sure if it is worth the work involved or if I should leave well enough alone.
Get a heat gun heat up the decal and it should pull right off. It you don't have a heat gun try a blow dryer or park in the sun. If you get the decal at the right temp it will come off close to clean if it leaves any residue get some gas(will not leave a residue) or goo gone(will leave a oily residue needs to be cleaned up) and clean.
I do not, i actually peeled off my STX sticker and put on a FX4. Mine came right off with some heat, the only thing you could see was where the sticker was it was like brand new paint, but all aound it there was mild surface scratches so you could see the outline of the sticker. No problem, cause my FX4 sticker covered the whole area.
