1989 f-150 Engine, Tranny, Wiring Harness Computer issues - Ford Truck Enthusiasts Forums
Old 10-11-2011, 09:00 PM
luckyguy1316 luckyguy1316 is offline
luckyguy1316 is starting off with a positive reputation.
I have a 1989 F150 that i put a 351 in (replaced the old 302) I also have the original transmission and wiring harness used with the 302. The tranny has been rebuilt and the motor is a reman. I have everything put in but the truck still is not running right. Have been told it is the computer issue. So I pulled a computer out of a 1989 Ford Bronco that has the C-6 tranny and a 351 in it but still is not running right. My mechanic keeps saying it is because the numbers do not match on the computer and it wont pass emissions. He has also told me that it is going to be almost impossible to find a matching computer for the tranny, motor and wiring harness. Wondering what my options are?
Old 10-11-2011, 09:11 PM
Terpfords's Avatar
Terpfords Terpfords is offline
Terpfords is starting off with a positive reputation.
Not running right how? I can't remember if a 89' 302 had a H.O. firing order, but in theory if you put a 351FI motor in place of a 302FI motor the computer wouldn't know.
I put a H.O. SEFI computer in place of a standard SEFI computer in a Cougar i had and it ran like a scalded ape. Broke the motor mount and overpowered the stock AOD.
Old 10-12-2011, 08:50 AM
well it wont shift out of first gear (Tranny has been rebuilt and was checked again by the company that did it). Verified the linkage is all correct. And the truck keeps stalling out. Brand new reman motor as well as new starter, battery, alternater, water pump, etc. Everything has been replaced with new or rebuilt parts except the wiring harness and the computer basically. Was told the tranny wont shift because the computer is differant need a specific code for it. Also was told the motor is stalling out because the code does not match that motor for the computer. Also been advised that the truck will not pass emissions unless the code for the computer matches the motor and the transmission.
On another note had differant mechanic tell me to put a computer in from a ford desiel pickup and it would solve my issues. Any thoughts on this?
Old 10-12-2011, 09:49 AM
Terpfords's Avatar
Yes, 89 computers don't control the transmission.
Start with the basics, double check your wiring and timing.
1989 302 to 351 engine swap help TrishaMarie 1978 - 1996 Big Bronco 3 05-24-2016 12:31 PM
1989 ford f150 302 to 351 swap bigcountry1985 1987 - 1996 F150 & Larger F-Series Trucks 20 05-12-2014 12:14 PM
Putting a 1990 351W and auto, into a 1989 302 5spd--- F150 reece9944 1987 - 1996 F150 & Larger F-Series Trucks 9 08-20-2013 12:53 AM
351 swap into 302 1989 bronco blake70 1987 - 1996 F150 & Larger F-Series Trucks 3 03-24-2012 12:17 AM
Motor Swap.. Do I need to swap Computers? KenDeGreat 1987 - 1996 F150 & Larger F-Series Trucks 26 01-02-2010 06:18 PM
Tags
150, 1989, 1994, 89, 96, computer, engine, f150, ford, harness, light, match, transmission, whereisthecompona1989f150, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
