2007 explorer w/ 4.6L spark plugs - Ford Truck Enthusiasts Forums
Old 10-11-2011, 06:31 PM
jjlrrw jjlrrw is offline
jjlrrw is starting off with a positive reputation.
Getting ready to change the spark plugs.
Anything special I need the know? All cylinders look easy to access even #4 and #8.
I read a service bulletin about only turning 1/8 turn adding some motocraft fluid and letting it soak for a minimum of fifteen minutes. Any idea on what years this covers?
Old 10-11-2011, 06:47 PM
TheWhiteBeast TheWhiteBeast is offline
TheWhiteBeast is gaining momentum as a positive member of FTE.
Yes, use some kind of break free because the spark plugs are 2 pieces and are prone to breaking. If you are turning it out and you start to feel it torquing, run it back in and try again, even if you have to do it over and over.
Old 10-12-2011, 08:17 AM
JWA's Avatar
JWA JWA is offline
JWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputation
1994 f150 4.9L 300 - Performance spark plug wires vs. regular spark plug wires? ElizabethRanee 1987 - 1996 F150 & Larger F-Series Trucks 1 04-09-2016 06:33 PM
Spark Plug Removal Video: The Ford TSB Way stkelly Explorer, Sport Trac, Mountaineer & Aviator 0 04-14-2013 12:25 PM
Motorweek- Pat Goss & Spark Plug Removal Technique Different from TSB- Much Different Beechkid 2004 - 2008 F150 10 12-19-2010 05:15 PM
Help No spark to spark plugs heafer 1987 - 1996 F150 & Larger F-Series Trucks 15 02-16-2010 10:23 AM
Replacing Spark plugs mrmac40 Explorer, Sport Trac, Mountaineer & Aviator 17 08-29-2003 06:19 PM
Tags
07, 2007, 46, 46l, change, explorer, exsplorer, f150, ford, iridium, original, plug, plugs, spark, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
