Favorite Fog Lights?
Old 10-11-2011, 05:26 PM
The Carpathia's Avatar
The Carpathia
The Carpathia is offline
Mine don't do diddly.
I want some that do diddly....that make the road like daylight down there.
Any recommendations?
It is a tough job?
TIA
Old 10-16-2011, 08:50 PM
ReAX's Avatar
ReAX
ReAX is offline
Piaa is my favorite, but you'll get comparable products from companies such KC hites and hella.
A couple quick things to notice on lamps, The lens should be glass. Plastics don't have the optical values glass does. The housing will last almost forever if it's Stainless, but quality powdercoat or chrome should last as long as you're going to keep your truck. The bulbs must be replace able, don't bother with anything that doesn't state what kind of bulb they take. H1 style is pretty common, but if you find an H4 that will have alot of options for wattage and hi/low beams. H4 is what was previously in most imports and widely used in motorcycles. I've seen h4 come as high as 140 watt low and 160 watt high beam. This is another reason glass lenses are important, once you get into the really high watt bulbs things start to melt.
Old 11-10-2011, 08:52 PM
Trophy_23's Avatar
Trophy_23
Trophy_23 is offline
I have heard really good things about light force, but they are pricey!!! I am looking at a set of Hella black magic, they look nice.
Old 11-19-2011, 10:08 AM
Aftrmidnite's Avatar
Aftrmidnite
Aftrmidnite is offline
SilverStar Ultra Headlamps; for clear or rainy weather use hi-beams, mild fog low beams. Heavy fog I switch to DRLs. Just an incredible lamp, so bright you almost need sunglasses for the reflective signs. No on-coming drivers refuse to go to low beams, LOL. Don't let anyone tell you they produce more heat, and will burn up your sockets. They are the same wattages, as regular lamps, so more energy is going out as light, and there will be less heat energy produced.
07EXPYEL
15
12-28-2015 12:45 PM
bri687
2004 - 2008 F150
03-17-2009 09:00 PM
Nathane
General Automotive Discussion
02-02-2007 05:43 PM
scarface78
1997-2006 Expedition & Navigator
11-12-2005 09:12 AM
4X4 IN REFUGIO
1999 to 2016 Super Duty
10-11-2005 12:31 PM
Quick Reply: Favorite Fog Lights?
