Go Back   Ford Truck Enthusiasts Forums > Misc. > Aftermarket Products
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Aftermarket Products SPONSORED BY:
  #1 (permalink)
Old 10-11-2011, 05:26 PM
The Carpathia The Carpathia is offline
Garage is empty, add now
The Carpathia is gaining momentum as a positive member of FTE.
Favorite Fog Lights?
Mine don't do diddly.
I want some that do diddly....that make the road like daylight down there.
Any recommendations?
It is a tough job?
TIA
  #2 (permalink)
Old 10-16-2011, 08:50 PM
ReAX's Avatar
ReAX ReAX is offline
2002 Ford F-250
ReAX is a name known to allReAX is a name known to allReAX is a name known to allReAX is a name known to allReAX is a name known to allReAX is a name known to all
Piaa is my favorite, but you'll get comparable products from companies such KC hites and hella.
A couple quick things to notice on lamps, The lens should be glass. Plastics don't have the optical values glass does. The housing will last almost forever if it's Stainless, but quality powdercoat or chrome should last as long as you're going to keep your truck. The bulbs must be replace able, don't bother with anything that doesn't state what kind of bulb they take. H1 style is pretty common, but if you find an H4 that will have alot of options for wattage and hi/low beams. H4 is what was previously in most imports and widely used in motorcycles. I've seen h4 come as high as 140 watt low and 160 watt high beam. This is another reason glass lenses are important, once you get into the really high watt bulbs things start to melt.
__________________
Too many mods to list, so click here.
Here are my tech write ups
Look, see these two tow hooks? They look like tusks. And what kind of animal has tusks?
  #3 (permalink)
Old 11-10-2011, 08:52 PM
Trophy_23's Avatar
Trophy_23 Trophy_23 is offline
Trophy_23 is gaining momentum as a positive member of FTE.
I have heard really good things about light force, but they are pricey!!! I am looking at a set of Hella black magic, they look nice.
__________________
2007 Black F350 Lariat FX4 SC SB
Duraflaps, Back Rack & Black Tool Box, Hitch Mount Back-up Lights, High Idle Mod, Insight CS, Dually tail gate ID bar, More to come...
  #4 (permalink)
Old 11-19-2011, 10:08 AM
Aftrmidnite Aftrmidnite is online now
Aftrmidnite is gaining momentum as a positive member of FTE.
SilverStar Ultra Headlamps; for clear or rainy weather use hi-beams, mild fog low beams. Heavy fog I switch to DRLs. Just an incredible lamp, so bright you almost need sunglasses for the reflective signs. No on-coming drivers refuse to go to low beams, LOL. Don't let anyone tell you they produce more heat, and will burn up your sockets. They are the same wattages, as regular lamps, so more energy is going out as light, and there will be less heat energy produced.
Tags
fog, fordtrucks, lamps
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
