truck dies and relays click rapidly
Whenever my truck dies my glowplug light and check engine lights come on and sometimes it will lose power and then come back real quick and sometimes it will take a few seconds to come back. A few times whenever it dies i can hear the relays for the idm and ecm clicking wildly like hundreds of times per second and i have took the relays out and swapped with another truck same thing so i jumpered the wires and the truck still dies...?? Could this be some sort of ground issue? Because when i hit bumps it makes the problem worse. Is there ford gremlins living in mhy truck?? Do u think raid bombs will run them off
just had this problem. it your cam position sensor. the relay that is clicking is the one right below the horn relay correct. if you hook your truck up to the computer it will more than likely come up with the code camshaft postion sensor intermitent. replace it and it will be fine. my truck was doing the same exact thing to the T
The only issue with that is that the recall sensor is junk. =( And the one they recalled is better.
agreed. i never had a problem but the ford dealership insisted that i needed the recal ( my truck had 390xxx on the factory cps) and two weeks later i had the same problem as you. i bought one from napa for $35 and no problems yet.
