fuel pump bad?? - Ford Truck Enthusiasts Forums
fuel pump bad??
Old 10-11-2011, 10:48 AM
sand1's Avatar
sand1 sand1 is offline
sand1 is starting off with a positive reputation.
fuel pump bad??
i was dxriving my truck then all sudden truck started losing power then slowly died i restartedx it it was a lil shacky then died again i unscrewedx the fuel filter and lookedxin the housing and there was lil fuel in bowl i turned the key to on position and bowl did not fill with fuel lookedx as if it were shooting some bubbles up(air) could it be outta of fuel???
Old 10-11-2011, 11:36 AM
Robert6401's Avatar
Robert6401 Robert6401 is offline
Robert6401 is a name known to allRobert6401 is a name known to allRobert6401 is a name known to allRobert6401 is a name known to allRobert6401 is a name known to allRobert6401 is a name known to all
Do you not know if you ran out of fuel? If not, that would be the first place to start. If it's not out of fuel, it is either the pump or a restriction in the lines somewhere. When you turn the key to the ON position (without cranking the engine) can you hear the fuel pump humming for about 10 seconds? Most make a little noise. It may help if you have a buddy lie under the truck and look at the pump while you turn the key on. It will be obvious if it is working when you turn the key on if you are looking at it. Typically these pumps either quit working all together, or work fine. Rarely any in-between. Let us know what you find and we will get you running again soon.
Old 10-11-2011, 11:59 AM
sand1's Avatar
Quote:
ok will check it toay and get update thxd
Old 10-11-2011, 12:26 PM
Shake-N-Bake's Avatar
Shake-N-Bake Shake-N-Bake is offline
Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.
Quote:
Originally Posted by sand1 View Post
... shooting some bubbles up(air) could it be outta of fuel???
Yep. The fuel pump is also pretty good at pumping air as well. When the fuel supply is exhausted, it will suck air through the fuel line connector between the pump and the tank.
Like Bob said, the fuel pumps are good one day and dead the next. They usually don't function in a partial capacity.
You might try getting yourself a jug of diesel fuel and manually plumbing it to the back of your fuel pump (make sure you use an inline filter of some sort). Cycle the key about 3 times and then start the engine. If it starts and idles fine then you will probably need to drop your tank and clean the screens (or perform the in-tank mods).
This is a fairly common issue.
Here is a link.
Welcome to guzzle's In-tank Hutch Mod Web Page
Old 10-11-2011, 02:17 PM
sand1's Avatar
ok will do
Old 10-12-2011, 03:15 PM
sand1's Avatar
checked fuel pump its working so i jus added 5 gallons of fuel and it started right up ran like **** for about 15mins(proably air in lines) and smoothed right out i guess i need to look at my sending unit instead lol thx fellas and im gonna drop the tank and mod the sucker
Old 10-12-2011, 04:25 PM
PaysonPSD's Avatar
PaysonPSD PaysonPSD is offline
PaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputation
You will probably find that the fuel pick up foot has deteriorated. It's become a more common problem as these trucks age. I did the in-tank mods about three years ago and didn't replace the pick up foot. It will fall apart sooner or later.
Old 10-12-2011, 05:48 PM
sand1's Avatar
Quote:
is there a link to in tank mod
Old 10-12-2011, 06:05 PM
PaysonPSD's Avatar
Get the sand out of your eyes. There's a link right at the bottom of Greg's post #4.
Old 10-21-2016, 11:51 PM
Brandon Davis Brandon Davis is offline
Brandon Davis is starting off with a positive reputation.
86 f350 6.9 idi
i have a question on my 6.9 idi. The truck shakes when running and is getting harder to crank. I just replaced the fuel filter screw on type today and it looked like muddy water and smelt like old gas which is diesel ofcourse. Then tried starting after i refilled new filter with clean diesel and nothing even bled injectors and a few air bubbles came out. Still wont crank. I disconnected the mechanical lift pump from the fuel filter the hard line on the lift pump itself and turned engine over and nothing came out. I have 3/4 a tank of fuel atleast. Bad lift pump?????? Thanks in advance.
Old 10-22-2016, 07:05 AM
Rikster-7700's Avatar
Rikster-7700 Rikster-7700 is offline
Rikster-7700 has a good reputation on FTE.Rikster-7700 has a good reputation on FTE.Rikster-7700 has a good reputation on FTE.
First, this thread is 5 years old, secondly you may want to put this in the appropriate forum for the year of your truck......
This forum is for the 99-03 powerstroke diesels, the fuel system on your truck is different to ours, we have electric rail mounted fuel pumps, whereas yours is a mechanical type.
No fuel to bowl DanS12 1994.5 - 1997 7.3L Power Stroke Diesel 16 07-04-2016 04:23 PM
97 no start Strokerboy73 1999 - 2003 7.3L Power Stroke Diesel 0 02-03-2016 10:17 PM
any tricks? kupiec20 1994.5 - 1997 7.3L Power Stroke Diesel 2 06-23-2015 12:20 PM
fuel bowls rodneywar 1994.5 - 1997 7.3L Power Stroke Diesel 9 04-18-2012 12:34 PM
Water in fuel light, truck wont start 3 black dogs 1999 to 2016 Super Duty 10 06-05-2009 08:35 PM
Tags
1999, 2003, 73, bad, diesel, excursion, flathead, ford, fuel, humming, inline, liter, located, pump, v8, weak
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
